Question about RCA L32HD31 32 in. LCD HDTV
Need codes to program direct tv remote for L32HD31R TV
5 Suggested Answers
SOURCE: dynex tv code
thanks for the dynex website. It is perfect I can use all the functions for the TV with my directtv:)
Posted on Sep 05, 2008
SOURCE: need code to progam remote
The Model L32HD31R, according to RCA, is not "code compatible". It cannot work with a universal remote, or cable/satellite remote. this is peculiar for a company like RCA, however I just bought the same model from Wal*Mart, and companies build models for certain stores. This one was built on the cheap, and one of the things left out of the mix was the "code compatibility".
Posted on Jul 11, 2009
  • 3 Answers
SOURCE: Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
Posted on Nov 20, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
How do I program a universal remote to an RCA Model L32HD31R
This is the general setup proceedings to a universal remote control.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the dropdown list by the 'Sidebar' of the display window. It will make search easy.
Mar 12, 2013 | RCA Televison & Video
My direct tv remote will not operate the volume for my new L32HD31R RCA TV
I can help you reprogram your RCA RCR311B for your RCA TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up on this remotes device code list.
I hope that helps.
Mar 01, 2010 | RCA RCR311B Remote Control
Have RCA L32HD31R flat screen TV. Codes for DirecTV sat. service do not work for their remote. Do you have any additional codes for this TV?
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
Jan 05, 2010 | RCA DIRECTV Satellite Remote Control
Hi Attychase,
Hope this helps.
Nov 20, 2009 | RCA L32HD31 32 in. LCD HDTV
I need code for RCA TV for Tivo remote
Go to http://support.tivo.com/app/answers/detail/a_id/294/kw/code%20search/c/105/r_id/100041 and under Programming TV Power, Volume and Mute, click on "show the steps".
Follow the instructions given.
The RCA remote codes are 0163, 0001, 0004, 0006, 0011, 0029, 0030, 0057, 0071, 0133, 0145, 0106, 0171, 0231, 0232, and 2210.
Try each of these codes one at a time (as per instructions) until you find one that works.
This link also gives instructions on what to do if none of the above codes work.
If this helps, please give a rating!
Oct 09, 2009 | Tivo Series2 TCD649080 Video Recorder
RCA L32HD31R/Dish Network Remote Code Problem
The word from RCA technical support is that the remote for the L32HD31R operates on a different frequency and there is currently NO universal remote on the market that will work with the set. They say that they have plans to market a universal remote and that they are working with other manufactuers of remotes but there is no resolution or time frame available. In short, you will have to use two remotes and keep checking the RCA website for a breakthrough.
I'm not sure that I would have bought the TV if I'd known.
Jun 26, 2009 | RCA L32HD31 32 in. LCD HDTV
Need code to progam remote . I have a RCA TV Model L32HD31R that needs to program to cable vision remote
Jun 17, 2009 | RCA L32HD31 32 in. LCD HDTV
I have the RCA model L32HD31R LCD TV and I need the 5 digit code for the Comcast DVR remote with the red OK button
I have a RCA model L32HD31R LCD, also but the codes from comcast will not turn tv on or off.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
REMOTE CODE
[ http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1 ] Please copy this web page link and paste it into the address bar of your web browser. This web link will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using Fix Ya and have a nice day.
Jun 06, 2009 | RCA DIRECTV Satellite Remote Control
RCA L32HD31 32 in. LCD HDTV Logo
384 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
