Question about MSI K8N Neo4-F Motherboard
MSI motherboard, Front Audio Panel for headphone don't work.
Hi,I bought a new PC and got MSI motherboard but the front panel for audio don't work. The cable is properly pinned at its place in the motherboard. Is there any BIOs settings for this???
    Problem Solver:
  • 12 Answers
On this motherboard you can enable or disbale the rear panel audio using jumpers on the motherboard. The jumper is labelled JAUD1. I'm assuming that if you select the rear panel, then the front panel will not work. This info is on page 36 of the PDF manual which can download from MSI. Good luck, the link to the manual follows:-
http://www.msi.com/index.php?func=downloadfile&dno=4117&type=manual
Posted on Oct 09, 2009
  • 76 Answers
Sometimes there are settings, you may want to check the BIOS or even with the manual for the motherboard it should tell you in there what you need to do to get it working.
Posted on Sep 30, 2009
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
Hi i am gaurav i have problem with sound.when i connect my headphones in front panel it dose'nt work.then i check the disable front panel jack detection in realtek manager.then i got i the sound but the...
Surely your headphones are working fine. So it can be either software or hardware problem.
To check if any problem with drivers, go to device manager, uninstall the drivers for audio, and reinstall a fresh piece of audio drivers. Restart the system and now check the sound. If the problem exists, then its hardware problem.
Since front panel and back panel are not working, then it can be the problem with the audio sockets of the motherboard. You have to consult a technician for that.
Hope your sounds get ok with the driver install. Thanks
Apr 20, 2010 | Computers & Internet
K9N6PGM2 motherboard cant get front audio micrphone and headphone sockets to work
In my case, it was solved by tweeking the sound utility, and not by touching anything in the computer:
  1. Make sure "Realtek Audio Manager" is installed (should come with the drivers)
  2. Start The "Realtek Audio Manager" (can do it by plugging earphones to the audio jack on the rear - the one the works)
  3. Look for the configuration tab - something like "Connector Settings"
  4. Set the "Disable front panel jack detection" checkbox
  5. Press [OK]
  6. Try again to connect the earphones to the front panel
See link from MSI forums:
http://forum-en.msi.com/index.php?topic=120665.msg911410#msg911410
Oct 16, 2009 | Computers & Internet
Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Jun 03, 2009 | Intel D865GBF Motherboard
Headphone problem
Did you installed all drivers ?
Are there FRONT audio jacks you are trying to connect your headphones/mic ?
Dit it work before ?
First install all (incl. audio) drivers and try to get audio from BACK connectors (Green is speakers/headphones, Pink is Mic.)
If it workson on REAR, but not on FRONT connectors, check if you have another icon for AUDIO settings in Control panel and try to set FRONT audio settings.
Check if FRONT audio connectors are connected to your motherboard.
Regards.
Check
Mar 28, 2009 | Intel Motherboard, G31 Express, Core 2...
Can't get headphone jack on front of computer to work
The headphone jack up front may not be connected to the PC's integrated audio on the motherboard (or to the PC's sound card if you purchased one with the system instead. There'll be an audio cable running from the front of the computer to a port on the motherboard. If you look at this motherboard diagram for the Vostro 220 (not the 420 or 220s), it'll be the port numbered "15" that's the opne for the audio for the front panel. You don't need the speakers plugged on the back to have the headphones work, but having them plugged in will at least tell you if the sound is working or not.
Mar 27, 2009 | Dell Vostro 220 Desktop Computer
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
Need to know where the black yellow speaker wire gets plugged into a msi k9a2 platinum
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
Apr 23, 2008 | Intel Motherboard
MSI K8N Neo4-F Motherboard Logo
1,856 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
