Question about Pioneer PRO-530HDi 53" Rear Projection Television
Lamp cleaning, how do i remove front sceen to get to lamps?
    Problem Solver:
  • 12 Answers
You really dont want to mess with the lamps. If you're seeing dust and build up on the screen, it is more than likely on the screen itself.
Posted on Sep 30, 2009
My model hlp 4674 wx/xaa sceen won"t do anything
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
I have a SONY TV KDF-E55A20, it turns on and off by itself, when I turn it on just can watch it for 5 seconds..more less, then thr Tv turn off and after other 5 seconds turn on by itself...and it keep...
The problem is the lamp has to be replaced. As it gets older and ready to fail outright, it will do this.
The lamp is located on the front lower left of center behind the front panel. There may be a thumb knob on back of each side that must be loosen, then the front panel pulls off. There is a door with another thumb knob on it. loosen the knob and remove the door. the lamp is held in place with allen wrench screws. loosen these and the lamp will pull out. The lamp part number is XL2200U.
It usually cost around $180.00 and it come with a allen wrench to remove and reinstall the lamp if you get it from Sony. The customer support number is 1800-222-SONY.
Once the new lamp is in, reverse the dis-assembly.
I hope this helps,
Skyassoc
Dec 14, 2010 | Sony KDF-E55A20 55 in. LCD Television
2006 jeep grand cherokee front headlight removal blue print
  1. Disconnect and isolate the battery negative cable.
  2. Remove the cover from over the top of the front lamp unit
  3. Remove the grille from the front of the vehicle.
  4. If the front lamp being serviced is on the same side of the vehicle as the engine fresh air intake tube, unsnap the air intake tube from the air cleaner housing and remove it from between the lamp and the radiator yoke.
  5. Remove the three screws (3) that secure the two lower and the upper inboard lamp mounting brackets to the front end sheet metal.
  6. If equipped, remove the push pin fastener (2) that secures the upper outboard lamp mounting bracket to the top of the radiator yoke
  7. The lower inboard lamp mounting bracket is captured between a metal mounting bracket on the top of the front frame cross-member and a tab of the plastic front fascia reinforcement. Push the tab of the front fascia reinforcement forward far enough for lamp mounting bracket clearance while maneuvering the lamp unit inboard during removal.
  8. Pull the lamp away from the front of the vehicle far enough to access and disconnect the headlamp and dash wire harness connector (5) from the pigtail connector on the back of the lamp housing.
  9. Remove the lamp unit from the vehicle.
Oct 16, 2010 | 2006 Jeep Grand Cherokee
How do I replace the fog light assembly on a 2000 Olds Alero?
you replace the fog lamps by going under front bumper fascia.remove the pushpins and take down the splash shield to access the back of the fog lamps.then you remove two bolts retaining the fog lamp to the back of front bumper.besure to wear clean gloves.because fog lamps is halogen bulbs.if you touch with bare hands the oils from hands will make the bulbs over heat and blow out.
Dec 03, 2009 | 1999 Oldsmobile Alero
Need a fuse box diagram to wire in fog lights
Fog lamps are installed on the front bumper. The switch is located to the left of the steering column on the dash panel. The fog lamps are turned off by the circuit relay when the high beam driving lamps are turned on. The circuit relay is located on the right front wheelhouse panel near the blower motor.
Good luck, and remember rated this help.
Removal & InstallationFog Lamp Element
See Figure 1
Fig. 1: Exploded view of a fog lamp assembly
  1. Remove the lamp stone shields, the four bezel attaching screws, and the bezel.
  2. Remove the reflector assembly from the lamp body.
  3. Remove the bulb holder from the assembly. Remove the element from the bulb.
DO NOT handle elements with your bare hands, always handle with a clean cloth. Oil from your hands will cause the element to fail.
  1. Installation is the reverse of removal.
Fog Lamp Switch
The fog lamp switch is removed and installed by simply prying the switch from the instrument panel and unplugging the electrical connector.
FOGLAMP BEAM ADJUSTMENT
  1. Position the vehicle on a level surface, facing a wall approximately 25 feet away. Remove the lamp stone shields and loosen the adjustment nuts.
  2. Turn the fog lamps ON and adjust as follows:
    1. Distance between the light beam centers should be equal to the distance between the lamp assemblies on the bumper.
    2. Height of the light beams on the wall should be 4 inches less than the center of the lamp assemblies when mounted on the bumper.
  3. Install all previously removed items after turning OFF the fog lamps.
1995 Cherokee Chassis Schematic
www.autozone.com
Aug 11, 2009 | 1995 Jeep Cherokee
Need to get the headlamp assembly off a 2006 jeep grand cherokee how do I get it off?
1. Disconnect and isolate the battery negative cable. 2. Remove the cover from over the top of the front lamp unit (1). (Refer to 08 - Electrical/8L - Lamps and Lighting/Lamps/Lighting - Exterior/UNIT, Front Lamp - Removal) . 3. Remove the grille from the front of the vehicle. (Refer to 23 - Body/Exterior/GRILLE - Removal) . 4. If the front lamp being serviced is on the same side of the vehicle as the engine fresh air intake tube, unsnap the air intake tube from the air cleaner housing and remove it from between the lamp and the radiator yoke hydroform. 5. Remove the three screws (3) that secure the two lower and the upper inboard lamp mounting brackets to the front end sheet metal. 6. If equipped, remove the push pin fastener (2) that secures the upper outboard lamp mounting bracket to the top of the radiator yoke hydroform. 7. The lower inboard lamp mounting bracket is captured between a metal mounting bracket on the top of the front frame crossmember and a tab of the plastic front fascia reinforcement. Push the tab of the front fascia reinforcement forward far enough for lamp mounting bracket clearance while maneuvering the lamp unit inboard during removal. 8. Pull the lamp away from the front of the vehicle far enough to access and disconnect the headlamp and dash wire harness connector (5) from the pigtail connector on the back of the lamp housing. 9. Remove the lamp unit from the vehicle.
Jul 17, 2009 | 2006 Jeep Grand Cherokee
Trying to change the front passenger turn light
Cornering Lamp Removal & Installation To Remove:
  1. Remove the bulb socket from the cornering lamp.
  2. Release the cornering lamp forward retaining tab and pull the front of the lamp away from the fascia.
  3. Remove the cornering lamp rearward retaining stem from the fascia by pulling the lamp forward.
To Install:
  1. Place the cornering lamp rearward retaining stem into the slot in the fascia.
  2. Engage the cornering lamp forward retaining tab into the fascia by pushing in on the front of the lamp.
  3. Install the bulb socket into the cornering lamp.
Jul 10, 2009 | 2004 Chevrolet TrailBlazer
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
LAMP not switching on NEC HT410
I had the exact same problem and solved it. After calling NEC tech and getting no help, my son and I decided to:
  • Remove, clean and reset lamp.
  • Completely clean (with compressed air) system.
And it worked. Here's what we did.
  • Removed lamp and cleaned with compressed air (in cans).
  • Used two cans of air to completely remove all internal dust. In our case long over due.
  • Reinstalled lamp and reset meter. (To reset: Turn on machine, wait 2 minutes or so, then hold down the "Help" button right next to the infrared sensor on the front of the machine).
Works fine now! Dont know if it was technical solution but solved it for us! Good Luck!
Jan 25, 2009 | NEC HT410 Multimedia Projector
Replacement lamp
Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on disengages.
Remove the screw securing the lamp cover with a Phillips head screw driver
Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers
Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly. Install the front cover. There is also a video on youtube just do a search on how to install a projection lamp. Hope this is helpful
Aug 22, 2008 | Hitachi 50V715 50" Rear Projection...
Pioneer PRO-530HDi 53" Rear Projection Television Logo
90 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
