Question about GPX MW3837 MP3 Player
Wont turn on
There not really very many instruction, the on hold off buttun doesnt seem to be a three way switch i switch it to on , nothing happens, i switch it to on the press the play button and it diplays hold then bye and cuts off. please help its a gift for someone.
  • Susan5 Dec 31, 2007
    I am having the same problem. I put songs on the MP3 player model MW3837 GPX and I charged it for over 10 hours and it doesn't do or play anything. It doesn't even come on. It's like it's dead completely. I can't seem to get any help from anywhere. What a waste of money!
Make sure the button on the left side that says on-hold-off is in the off position, then try turning it on by pressing and holding down the play/pause circle button on the front of the mp3 player.
Posted on Mar 03, 2008
Yep that worked!
When turning the ignition switch on my LT 1000 craftsman tractor, it doesnt do anything. I have replaced the battery fuse and the ignition switch and nothing happens. The lights doesnt come on either. It...
You may either need a seat switch,pto switch or a park break switch.If the tracter is in nuetral with the park break set,it should start with out anyone on the seat,eliminating the seat switch.If you on the seat and the park brake is pushed and it wont start make sure the pto is off,if it is and nothing happens,then it's likely the parkbrake switch.Also check the connections on the battery,starter and engine block[ground].Let me know how you make out.
Mar 17, 2011 | Craftsman Garden
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Jan 11, 2011 | Amazon Kindle Wireless Reading Device
I have a 2005 yamaha yfz450 when i turn the ignition on the nutreul light comes on so the batteries charged then when i press the start buttun nothing happens... i checked the plug and there was no spark...
hi,because the light comes on,it doesnt necessarily mean the battery is charged,the neutral light draws very little and will come on at about 3 volts you need at least 12.5 ,so check the voltage across the battery and charge if needed,hope this helps..cheers
Mar 06, 2010 | 2004 Yamaha YZ 250 F
I have infinity computer speakers and they wont
Read and follow the owner manuals instructions. Also make sure your computer doesnt have the sound muted.
Aug 14, 2009 | Logitech Z-2300 Computer Speakers
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Press to start-nothing happens-no buttons pushed respond
IN MY CASE, IT WAS THE "HEAT DRY" PAD. THE CONTROLS WERE LOCKED INADVERTANTLY. NEED TO PRESS AND HOLD FOR THREE SECONDS TO UNLOCK. I FOUND THE INSTRUCTIONS ON THE WEB.
Apr 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Help
Hi, Try this out...
1) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 28, 2009 | Apple iPod nano
89 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
