Question about Samsung SyncMaster 920NW Monitor
The power save light is blinking and the screen is black, but I cannot get it to turn on. Have rebooted everything. Disconnected the cord and just tried the monitor only. Hit Enter. Nothing is working
  • 76 Answers
When you have the monitor by itself will it power on at all? You should be at least able to get to the menu. If not its likely the monitor itself is faulty.
Posted on Sep 30, 2009
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
I had a power outage due to too many appliances going. In switching circuit breaker back, my PC doesn't connect to internet via ethernet.
First thing to try is rebooting your modem. Do this by removing the power cord from the modem and wait a couple of minutes and plug it back in. The lights on the modem should start blinking right after plugging it back in and it will take a while before it has rebooted completely. If the modem lights do not blink after you plug the power cord back in, there is a very good possibility that your modem has been "burned out" because of the procedure you used of just resetting the circuit breaker.
It could also be that your router needs to be reset. Open up your browser and look on the bottom of the router for an IP address; it looks like 192.168.0.1 After locating this number, copy it into the address box of the browser and press enter. After doing so, just follow the directions on the screen.
Jan 07, 2015 | Computers & Internet
My power button is blinking with a black screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 03, 2012 | Gateway Computers & Internet
Black screen on neo netbook
Does it boot and it seems like everything is running except the screen is black? If so try this:
Apr 20, 2012 | Computers & Internet
Xerox 4595 canot boot . power save button blinks
Count the blinks and the pattern of the blinks. Blinks and Beeps tells the technician what is going on with the laptop.
Maybe you have a Static Charge Buildup. Remove thePower Cord, Remove the Battery, then Press and Hold thepower button for 30 seconds. After 30 seconds plug the power cord back in(leave the battery out) and hit the power button to see if it boots. Ifit does, you can put the battery back in and let it charge.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 03, 2012 | Canon Computers & Internet
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
The power cord is turned on(blinking)but it doesn't want to start
It migth be powerjack problem. Try to move the jack very gently then plug it on and try like this one more time, If you get any moves, you need to take to Techguy.
You may have Bulb problem if you can't see the LCD. This is comes from inverter or Bulb. Or even graphic card. You need professional.
Goodluck
JMC
Aug 13, 2009 | Toshiba Satellite A45-S250 Notebook
LiquidVideo L17LCD2 17 in. Flat Panel LCD Monitor - Power Issues
firstly stop turning it off and on because you will blow something else like a power board then it will be a big paper weight.
next get a torch and when it is powered on and supposed to be showing images, shine the torch at the screen.
if you can see everything then you have a broken backlight or problem with your backlight and connections.
they cost approx £15 and a little labour, its not a big job. you may be able to do it yourself if you can get hold of a service manual.
Feb 26, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
BLINKING POWER LIGHT
HOW MANY TIMES DOE IT BLINK
BLINK: SHORT-LONG-BOTH-MIX
EXAMPLE: 1 LONG BLINK AND 1 FAST BLINK IS A VEDIO AND MY ALSO BE A BOIS ERROR TOO.
THE LONG LIGHT MAY MEAN A POWER ISSUES, FAULTY WIRE, FUALITY POWER SUPPLY, INTERMITTING POWER SIGNAL TO THE COMPUTER SYSTEM
3-1-2- HARD DRIVE DMA ERROR
ROD
Feb 02, 2009 | HP Pavilion a705w PC Desktop
HP FLAT SCREEN TV BLINKING POWER LIGHT/BLACK SCREEN
sounds like the power supply has gone bad.
Jan 04, 2008 | Computers & Internet
Samsung SyncMaster 920NW Monitor Logo
393 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
