Question about Sony Cyber-Shot DSC-F707 Digital Camera
I have a dsc-f707 and the camera claims no memory stick is in it. I replaced it with two memory sticks and still the same message. Plus, can Memory stick duo work in camera?
I only got one reply and it was a "spam ad" selling offers from different camera repair companies. I ended up calling a local camera repair place and basically was told that the camera is nonfixable. The cost to repair is most likely going to cost the same as buying a new 12M pixal camera. So, why fix it?
Posted on Oct 01, 2009
'dear sir, i am having a problem with myh computer: It is a s ony dscf707 I get the error message : ' c:13:01 cannot access the disK How to get it working again: thanks for your help.
The problem is that if you ever use the memory stick on other camera besides the Sony DSC-F707 or format the memory stick on a computer instead of using the camera's format feature, then you will experience the "Memory Stick Error C:13:01" problem.
Here's the solution that finally will solve your issue. Take any lead pencil. Take the eraser and rub it on the gold contacts on the memory stick as if you are erasing writing on paper.
Do this for about 30 seconds or more until you get all the gold contacts. Put the stick in the camera, switch to 'Setup', then turn the camera on. The 'C:13:01' error will automatically disappear. At this point, quickly format the memory stick using the camera's format feature.
CAUTION: NEVER FORMAT YOUR MEMORY STICK ON OTHER CAMERAS, USING A COMPUTER WITH A MEMORY STICK READER OR USING WINDOWS XP WITH A USB CABLE PLUGGED TO THE CAMERA. IT DOESN'T WORK. FORMAT YOUR MEMORY STICK USING THE CAMERA'S BUILT IN FUNCTION ONLY.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
Can i use sony memory stick duo for sony cyber shoot DSC-F707
The answer is yes as long as they are the same type memorystick.
Feb 10, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I insert a memory stick and it says "No memory Stick" although it will take and record pictures . Does anyone know where i can purchase a 128 Memory stick for the DSC -F707?
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
Jul 17, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony digital dsc-f707 startup goes to "no memory stick"
Could be that the contacts on the camera are oxidised. Try cleaning the contacts with isopropyl alcohol and see if this helps. If not, it could indicate a circuitry problem. In this case, you'd probably be better off buying a new cam altogether!
Sep 28, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory Stick Error
Have you tried re-formatting the cards? If you can't with the camera you should be able to with a card reader. It's probably the camera, unfortunately, but this is worth a shot...
Sep 13, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
F707 type of memory stick?
I bought a Lexar 256MB, since the F707 can't use PRO or anything about 128mb, it has two 128mb on one stick. There's a switch on the stick to change it when the first 128mb is full.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory stick problem
I had this same problem and the procedure it the following : IF YOU WANT TO SEE YOUR PICTURES, DOWNLOAD "PhotoRescue" INSERT YOUR MEMORY STICK CARD IN YOUR CAMERA, RUN THE SETUP1 AND FORMAT IT. Good luck
Sony Cyber-Shot DSC-F707 Digital Camera Logo
230 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
