My lab top hard memory is parted in c and d and I am running out of space in c drive. How to put them together
  • 4,806 Answers
1. Go to the Start menu and open Control Panel
2. Select the System and Maintenance option if you are using the Control Panel Home View and Administrative Tools if you are using the Classic View
3. In the Administrative Tools section, select Create and format disk partitions.
4. For Classic View users, select the Computer Management option and select Storage. When done, click Disk Management
5. When the list of your drive is displayed, choose the one with which you want to merge your partitioned drive with (e.g. disk D:) and select Delete Volume.
6. Hence, select your drive C: and the option Extend Volume. You computer will automatically select empty available spaces on your hard disk, and you can alter them if you wish to do so.
Regards.
Posted on Sep 30, 2009
    President:
  • 1,187 Answers
Microsoft does not have any utility to do this, other than to backup, delete and re-partition.
#1:
The best utility (in my opinion) is "Partition Commander" (any version) from Avanquest. Version 10 is the latest ($50 Fry's, Best Buy, OfficeDepot, Max, etc.)
Boot from the CD and you can add the D partition to the C partition. Works great!
#2:
Open [My Computer]
Right-click on Drive C
[Properties]
In the "General tab", click on [Disk Cleanup]
The system will "scan" your drive, but not change anything) and finally give you a list of things to clean.
Look at the list and accept most or all of the checked items and press [OK]
It will not delete any of your data. Only "background" stuff that you don't need.
#3:
A quick way, without purchasing anything is to make use of the D Drive...
Best way is to "move" "My Documents" from the C drive to the D Drive. If you have lots of data, then this will help.
[Start]
Right-click [My Documents]
[Properties]
in the "Target" tab, click on [Move]
Explore to Drive D and press [OK]
It will ask if you want to move the data, answer "Yes"
  • 1,029 Answers
You can increase the size by compression to save disk space you can right click on the hard drive, click Properties, and check"Compress drive to save disk spaces". The processmay take a long time a What it does is theprocess compress every file in the disk in to smaller size, notexpending the hard drive. The amount of space you save depends on thefiles you're storing. Image, music, or video files will not compressdown so you won't really be saving any space.
or alternatively you can use an external hard drive or use a third party software like partition magic Partition Magic allows you to create, resize and merge partitions.you can download the trial version here http://www.soft32.com/Download/free-trial/Partition_Magic/4-151-1.html
hope this helps
Dell studio low memory
Low memory problems could be low virtual (hard disk) memory.
Hard disk maintenance will free up hard disk memory space.
Hard disk maintenance should be carried once a month to make your computer run efficiently.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Jan 04, 2013 | Dell Computers & Internet
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
How can i free space for my virtual memory ?i don't need a solution for increasing the size of virtual memory instead i want to free space that has been occupied in the virtual memory.
Hey, You got to free space on your hard drive. The virtual memory resides on your hard drive. but if the hard drive is getting full, this will reduce the virtual memory. So make home for virtual memory by free space on your hard drive.
Apr 27, 2011 | Microsoft Windows XP Professional SP2 for...
I have a acer aspire one and this pop-up keeps coming up saying 'out of virtual memory' - i dont know what to do. Also every hour or so my theme changes to classic (i have Windows XP) for about 5-10...
Virtual memory is the space the laptop uses on the hard drive to write to and read from. It usually is caused by running too many applications at once, thereby putting a greater demand on the free disc space you have,
Firstly, you need to check how much free disc space you have. Less than say 1 GB will flag up the issue ( depending how much virtual memory the computer is allocating). You need to remove some data from the hard drive and back it up to free some disc space
Then consider upgrading your ram to help you run more programmes at once if needed
Finally, consider getting an external usb drive to store data on, or upgrade your hard drive
Jan 14, 2011 | Acer Computers & Internet
There is not enough disk space or memory to run word office 2010 on Win 7 Pro
You need a few gig free space on your hard drive to run modern programs.
How much free space is on your hard drive. They recomend 10% minimum free space.
Go to add/remove and delete as much as you can.
Run a program like CCleaner
Aug 03, 2010 | Microsoft Computers & Internet
My dell dimension 3000 PC has run out of memory space on the C-drive. How do I add more memory?
Looks like that computer ships with a standard 40GB drive. If you have ran out, you'd need to go to your local computer parts store (ie, frys) or buy an additional hard drive. Your computer uses the IDE interface for hard drives, which is a 40-pin connector. You can but these pretty cheap now. Once you get it, it's just a matter of opening the case, and putting it in there. You can't connect it to the wrong place.
Mar 25, 2010 | Dell Dimension 3000 PC Desktop
Can i add more space to my zen mp3 player
I do believe you can put a larger hard drive in it? try Ebay and see if they have replacement hard drives.
Feb 21, 2010 | Creative Labs ZEN SLEEK MP3 Player
I am receiving constant messages about my PC's virtual memory being low. How do I correct?
Hello.
Try freeing up some hard drive space,delete unwanted programs and files.
Go to programs,system tools and run disc clean up.after that run disc defragment.Defrag may take awhile.
This will clean up your hard drive and put it back in order.
reboot pc when done.Should get some memory back.
Jan 14, 2010 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
