Question about Midland LXT310 2-Way Radio
I would like to get the manual for Midland LXT326, Model 18cvp6Your drop down doesn't include the ZXT326 so I just entered the first one to get my request sent in.
4 Suggested Answers
  • 21 Answers
SOURCE: I have a pair of LXT326 Midland 2 way radios. Neither one will respond to the others call button, nor voice transmissions. They are both on the same channel and have no provacy codes set. Each will pi
Try the battery contacts. or replace with fresh batteries. Try setting the same privacy code in each and see if that clears it.
Posted on May 11, 2009
  • 5 Answers
SOURCE: i have a midland lxt326 im its supposed to work for 20 miles
The number of miles stated on the package pertain to the approximate distance you can contact somebody IF you were in an open field.
Keep in mind these radio signals travel by air, and if we have trees, houses, and tall buildings around us, the signals will meet interference and bounce around before reaching their destination.
In an urban area, the most you'll get is about 1 mile. I have the exact same radios as you, the LXT 326 model with black and blue on it, and I can use it to talk to family with a radius of about three blocks in every direction from my house. After that, the messages have a lot of static and are no longer understandable.
Posted on Dec 18, 2009
  • 164 Answers
SOURCE: DROPPED MIDLAND WEATHER RADIO - NOT WORKING NOW
I will be honest with you, I haven't had any problems with this, but I will give you my opinion on what you should do. You can try to call tech support, but I do not think they are going to replace your radio because under their one year warranty, it says that they will repair or replace, at its option without charge, your radio if it fails due to a defect in material or workmanship within One Year following the initial consumer purchase. In other words, they are probably going to feel like this was your fault and your sole responsibility for the radio not working, not the radio itself. I will give you two possible solutions that you can try, but the only solution maybe to just get a new one. My first solution is to actually open the radio by unscrewing the bottom screws (the other two bottom screws are under the black grip-pads), and checking the circuit board and other contractions inside the radio to make sure everything is still intact. I've never tried this with the weather radio, but I did try it with a digital tire gauge I had bought. The tire gauge was not coming on when it was supposed to. I opened it up and played with some of the parts in it. I'm still not finished fixing it, but I did see that it was working better than it was before. Try playing with the parts in the radio and then put the radio back together and turn it on. If this does not work, than it's likely something that cannot be replaced and you will have to get another one. They have them at Wal-Mart for $29.99. I don't know if you are running your radio just on batteries or not, but if you are, maybe you should change the batteries. I hope this works out for you and remember, this is just a suggestion.
Posted on Sep 25, 2010
New batteries; worked great for two days; now will not turn on, either unit!
Check your charger.
Check your radio programming.
Post back with further questions.
Best regards.
Jan 02, 2016 | Midland LXT326 Two Way Radio
What voltage DC charger does a Midland LXT326 use?
http://www.buytwowayradios.com/Products/Midland/manuals/LXT-345-manual.pdf
I don't see it in there either. But since the battery is 4.8v, my educated guess would be somewhere around 6v. Its not stated in the manual though, and you can't see it on the picture towards the end where they offer a charger.
I don't know if you can charge by putting your own batteries in there. I'm guessing probably not, they usually put a different contact in there for the battery pack so you don't accidentally attempt to charge standard batteries.
Jul 09, 2014 | Midland Radio Communications
How many batteries connected in series at the battery pack there is?each one is 1.2 Volts, just add each one and add 10% Voltage.The final voltage is it
I want to get a head set for is but i dont know what the dubble prong plugin is called or what size i need to order i know there are 4 or 5 types.
You should be able to put in the make/model number followed by headset and that will get you to the ones you need.
Jan 21, 2013 | Midland LXT326 Two Way Radio
Instructions for one for all universal remote
Manuals for most One For All products are available here: http://www.oneforall.com/support/manual . Use the drop down menus to select Universal Remote and the model. You may have to change the region at the top of the page. The direct link to the URC-4605 manual is http://www.oneforall.com/uploads/support/ee688b75659e6a4d88dbf6b306de1e5e.pdf . Note: this manual doesn't include a code list.
Oct 26, 2011 | One For All URC-4605 Remote Control
Need a midland 74-210 weather radio manual
I posted (or attempted to) a manual 5-22-11....if it doesn't show up contact me.......
Apr 21, 2011 | Midland 74-210 Radio
Lxt326 how to turn it on
press the menu button for three seconds
Jan 18, 2011 | Midland LXT310 2-Way Radio
I have a midland lxt326 im its supposed to work for 20 miles
Sep 26, 2009 | Radio Communications
Midland LXT310 2-Way Radio Logo
788 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
