Question about Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB - 102608-056-B - Biscuit
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
    Problem Solver:
  • 15 Answers
Make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Posted on Oct 04, 2009
Cetra jetted bathtub. Is ground strap required?
The ground strap could be a local code requirement.
Nov 02, 2015 | Jacuzzi Home
My jacuzzi tub will not come on . fist it was making a humming sound , i turned it off checked the reset plug tried to turn it on and not a sound
mine did the same thing. the tub is plugged into a ground fault interupter (gfi) plug. hit the reset button. if this doesn't work, check the circuit the gfi is on, sometimes they are on the same circuit as the plugs at the sink. check them for reset also. if this fails, on the motor of the tub, there should be a reset button. try to reset it. OH first make sure the breaker has not been tripped.
Jan 04, 2011 | Jacuzzi 4481-959 Nova 5 Soaking Bath 5'-...
I recently turned the breakers in my homes circuit box off and back on, now the whirl pool tub jets won't come on. Is there a reset button on it or something?
This depends on when the tub was installed. By electrical code (NEC) all jetted tubs have to be GFCI protected. You may have to look for an outlet shaped devise with a rest button on it. Some jetted tubs have 2, one for motor and one for heat. Some electricians place the GFCIs in the same area as the motor for the tub. Also by code the motors have to be accessable, so there should be a door that opens up to expose the motor for servicing. You may find the GFCIs there, if so, check that they are reset, and have power. You can use a standard lamp if nothing else to check the power (sometimes multimeters lie, so I like to use something that proves current flow like a lamp, vacuum, drill, etc.)
That should get you on the right track.
Oct 27, 2009 | Jacuzzi Home
Jet tub just wont start
well i''m a plumber and it wouldn't be one of our problems. most likely, the electrishians didn't hook power up to it, or they did it wrong and burn't it out.
Sep 19, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Bathtub jacuzzi (motor turns on but nothing comes out of jets)
open the the repiar panel and see if the pump is working. you may hear the motor running but not the pump.
Nov 21, 2008 | Home
Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
Nov 21, 2008 | Home
Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB - 102608-056-B - Biscuit Logo
1,084 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
