Question about Samsung Televison & Video
Manual to setup samsung tv remote BP59-00107A
Why does my Samsung not turn off my cable box?
It sounds like the box and TV are out of sync. If the DVR is shut off, turn off the TV manually (NOT with the remote.) The next time you hit the power on the remote, both units should power up together. Make sure the remote is pointed at both device at the same time and slowly sweep the remote to hit both of them while holding the power button. I have always used the cable/DVR remote to control my devices and left the TV remote in a basket for setup stuff only on the TV.
Jan 31, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
I have a new Samsung smart tv and I'm trying to set up the universal remote setup feature with my Motorola DCH6200 Set-top box. It doesn't seem to recognize my set-top box model number
Find the manufacturers website for the universal remote and download the codes for samsung smart tv, probably will be able to find a general code in the online manual of the remote.
Dec 30, 2013 | Televison & Video
I have direct tv and want the remote to work
0568,0193,0182,0162,0155 are the codes to check. If you wish to get more setup codes, check this link. Setup code list to DirectTV remote control are given. Pull up older posts.
Mar 04, 2013 | Samsung AH5900092W Remote Control
I NEED THE MANUAL CODE FOR A SANYO RMT-U130 UNIVERSAL REMOTE FOR MY SAMSUNG TV
If you know the setup codes to check with your TV brand,
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you do not know the setup codes, and wish to know more about setup codes and setup proceedings to many brand remote controls, check this site. General setup codes to check with Samsung brand TVs are : 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Jan 23, 2013 | Samsung Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
Manually input channels. Lost remote to tv.
You can navigate the menu using the buttons on the tv. Go to the setup menu and you can do a channel scan. You can get remote from Shopjimmy.com,Ebay or Samsung.
Aug 31, 2011 | Samsung Televison & Video
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
I have a LG TV Universal remote and I'm trying to program it to a Samsung DVD/VCR Combo and I'm not able to do this. The remote model # is MKJ32022834.
TV manual has instruction and codes, or Check www.remotecentral.com for the manual and codes. Some combo setups won't work with alot of the universal remotes tha come with TV's. Also Try aftermarket universal remote.
Mar 14, 2010 | Directed 434MHZ Remote Control
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Televison & Video Logo
379 people viewed this question
Henry  Thomas
Henry Thomas
