Question about OEM Systems Car Audio & Video
I have a 2000 cadillac sls. Battery ran down, can't use radio&CD
I have a 2000 cadillac sls. My battery ran down and now my radio volume is low and I can't initialize the cd player!
    Problem Solver:
  • 6 Answers
Try disconnecting your battery for 10 minutes to reset the radio and factory amp. Disconnect negative terminal only and avoid touching your 8mm wrench to the positive post(s). Read the warnings on top of the battery about smoking and open flames and safety glasses too, or you can read the owner's manual and pull the radio memory fuse for 10 minutes.
-JMFT
Posted on Oct 01, 2009
2000 T+C battery ran down....now radio can barely hear..is there a seperate amp with a fuse?
there is an amp located in the back rear drivers side, check that, and there are fuses near battery , a radio fuse and also an amp fuse, i change my battery every 3 years as a prevention so I don't get stuck.
Feb 12, 2015 | 2000 Chrysler Town & Country
My 2000 Cadillac Seville SLS jerks when I give it gas and it eventually cuts off what could be the problem
If check engine light is on have it scanned at auto parts store .if no codes then could be low fuel pressure or a coil pack shutting down. Please rate my help
Nov 24, 2014 | 2000 Cadillac Seville SLS
2000 Cadillac ran out of gas I put gas in it and battery died I got a jump and it still won't start
if you ran out of gas this will not cause a battery to go dead. you may have a charging problem causing the car to run only off of the battery voltage until the battery was too low to run the ignition system and died.
Aug 09, 2014 | Cars & Trucks
1994 Cadillac Fleetwood Radio. Once turned on the display cuts out, you can tune the radio to a station. The problem i'm having is that the radio will go from low volume to very high and then cut off...
Most likely, you will have to remove the radio
& take it to a car radio shop
Not many around anymore
They usually resolder whatever & put a
new belt on your Cassette or CD Drive & your good to go
Aug 03, 2011 | 1994 Cadillac Fleetwood
Display says it is running at 190 degrees is this safe? 1995 Cadillac Seville
Yes. Mine tends to run in the low two hundreds and will sometimes get to 225 before cooling down. I was told that this was they way they ran due to the aluminum engine. I have no idea whether it is true or not, but what I do know is that I have read countless forums from new owners asking about this, including myself at one point, and all the experienced owners tend to say,"Don't worry about it, this is how they run."
If you haven't already search 95 sls temperature. Try this one for starters:
http://www.cadillacforum.com/forum/aluminum-block-v8s-49/95-sls-overheating-11076/
Aug 03, 2011 | 1995 Cadillac Seville
1997 CADILLAC SLS THEFT PROBLEM ON THE ECU I WANT TO RESET IT?
Pull both battery cables, let the car sit for 20 minutes then put them back on.
Feb 25, 2010 | Vehicle Parts & Accessories
I have a 2000 cadillac catera my radio, maplight, high beam light, heated seats, and onstar does not work when I start the engine. when I turn it off they work until I open the door. PLEASE HELP
Did you recently have a loss of power to the car? change the battery? if so, you need to reset your system. My husband and I just figured this out this weekend. His sunroof hasn't worked in two years and it turns out you have to reset all the power options in the car. Google 2000 cadillac catera %calibrate ETC% loss of power, you'll find the step by step instructions for recalibrating the car's computer and resetting the power options
Mar 15, 2009 | 2000 Cadillac Catera
1998 seville sls airbag light on
I woul dgive disconnecting the battery for 30 minutes a shot
Feb 10, 2009 | 2000 Cadillac Seville
Car Audio & Video Logo
120 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
