Question about Samsung SMH7178STD Microwave Oven
Charcoal filter I bought SMH7178STD samsung microwave oven. I try to put in charcoal filter. I coundn't do it. I mean I try to take out upper part. but it didn't take out. Would you help me?
  • Anonymous Oct 28, 2008
    Same problem. Called Samsung and they wanted to charge me to send out a technician. Stupid design flaw. If anyone has figured this out please let me know asap thaipham@rogers.com
If you look on top of the microwave, at the top there are two screws. undo the screws and the black plastic grill slides to the side and pops off. the charcol filter then slides in to the center area.hope this helps.
Posted on Feb 04, 2008
  • 833 Answers
Sami...most of these units use a spring on the inside of the micro to hold the filter frame in place. Push back on the filter against the spring and then tilt it out.
Posted on Dec 19, 2007
    New Friend:
After you take the two screws out you have to slide the grill to the left to clear the door.
Posted on Nov 02, 2013
I have the same exact problem. The unit has a top grill nothing like that shown or explained in the manual. It is not possible to come out like they say and i dont want to break it.
Posted on Jan 30, 2008
We installed new microwave and don't know where the charcoal filter goes
Open the door and take off the upper side barre. and you are in bussnis
Sep 28, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
My Samsung SMH7178STD gives me an error condition that flashes -SE- and beeps every so often but i can not get rid of the error condition. I have unplugged to perhaps reset it but it still flashes the same...
Hello :
SE error means you have a shorted keypad . If you couldn't find parts , then It will be cheaper to replace the unit or have new one .
good luck .
please rate !
Mar 30, 2010 | Samsung SMH7178STD Microwave Oven
My samsung SMH7178std microwave doesn't heat anything up. it makes a buzzing sound after i set timer and press start.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jgk
Feb 10, 2010 | Samsung SMH7178STD Microwave Oven
Does this microwave oven use charcoal filters
Hi.
The only time your microwave will use a charcoal filter is if it is mounted over the stove, as a microhood, and discharges into the room, rather than up a stack. If yours is set up as a hood, you'll have the woven grease traps underneath, and the filter will be behind the upper grille.
Best regards, --W/D--
Aug 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
Microwave make a deep humming sound ,does not heat and the circuit breaks
I would say your magnetron has failed.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the one-year time frame, the repairs should be free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Samsung SMH7178STD Microwave Oven
SMH7178STD Not working properly
E4 means your thermistor (temperature sensor) is shorted or caked with grease, making it look shorted.
Normally you can get Samsung parts here: http://www.samsungparts.com/search/search.asp
But that part does not show up on a search so you'll probably have to call them:
J & J International, Inc.
311 Route 46 W, Suite E
Fairfield, NJ 07004
Tel 800.627.4368
Fax 973.276.9078
Jan 21, 2008 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
