Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Can not get any digital progams now that I have retuned my panasonic dmr-ex75eb dvd recorder. Am not receiving any digital signals
  • manda_payne Oct 02, 2009
    I pursuing a solution with Panasonic.
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
I had the same problem! I have the singnal connected to a digital converter box, to the recorder, and then to the tv. the digital channels work ok on the tv from the converter box. However, they do not work on the recorder.
Posted on Jun 03, 2008
SOURCE: Panasonic DMR-EX75 has stoped receiving digital signal
Have you tried re-tunning the dvd?
Posted on Aug 04, 2009
Obertelli
  • 3006 Answers
SOURCE: Cannot get any digital channels since local digital switch over
The official line on this is that you should try and retune again, but there are some Panasonic models with similar model numbers to yours which have been specifically identified as having incompatibility problems with the Freeview retune.
However, your model is definitely not one which appears on the problem list, so it's worth checking that your aerial wasn't misaligned or damaged during the gales last weekend. In addition the Winter Hill transmitter is currently undergoing work until December which will significantly boost the digital signal and give it HDTV capability, so your box may have have been knocked out of kilter if the current digital service was temporarily operating at restricted capacity. Digital signals are by their nature much weaker than analogue tv and if you have a marginal aerial system which has been up for many years and which feeds a number of televisions in the house then it's definitely a good idea to see about upgrading your aerial system.
The difference in actual parts costs between a top spec aerial system and a poor one are surprisingly low, it's also easily possible with careful design and installation to get a better performance with poor parts than you can get with a poorly designed and installed system using top quality parts. One thing does hold true though: a well designed and installed system using poor parts will only last a few years before needing serious attention but a proper job can last up to thirty years.
If you're sure about your aerial system and retuning does not help, then you'll need to contact Panasonic directly. The first web address below will give you their contact number along with a list of Freeview boxes with known retune issues. A second web address which I've given takes you to an excellent Sheffield based tv aerial company which has an incredibly informative website.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
http://www.aerialsandtv.com/index.html#ATVinfo
I hope that you've found my answer to be helpful and ask only that you return the favour by rating my answer.
Posted on Oct 05, 2009
Grubhead
  • 5126 Answers
SOURCE: DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Posted on Mar 01, 2010
  • 102366 Answers
SOURCE: panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Posted on Sep 30, 2010
DMR-EX75B - tuning gone with clock
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Mar 04, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Good reception on analogue but no digital
Try RESETTING THE SYSTEM it is in OTHERS in the menu and make sure language and location are correct then retune you might be asked for code if you have not changed it enter 1234 or 0000 or 5555 or 8888 these are the most factory codes used
Nov 07, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Oct 05, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Error U80
Hi all smilerand here, an update
Although my unit had a new drive fitted paid for by panasonic. This did not solve the problem. It turned out to be a back end printed circuit board(PCB), which panasonic paid the costs of.
So this PCB could be the problem with all your units if this is any help
Oct 21, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Playing HD Video
This machine won't play HD-DVD. What it Will do is to play standard discs and upconvert them to your HDMI format...accordianman
Jan 06, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
295 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
