My konica 3331 is giving me an error code 36-C1 ,what should i do.
  • 158 Answers
Thid is a fuser error code causes could be heat lamp, thermistor, thermofuse or circuit board
Posted on Oct 03, 2009
Error code c9401 konica minolta bizhub 36
Scanner lamp assembly, that is the bright light that come on the document feeder, there is a problem with it. Need to be replaced. or the control board needs to be replaced. No reset
Sep 06, 2014 | Konica Minolta Office Equipment & Supplies
Konica 7020 trouble code 36-1
dear need help to resite l detect value auto adjustment developer konica 7020
Feb 26, 2013 | Office Equipment & Supplies
My konica 1112 copier is showing 36 error it does;t work
it will be showing j-36, its the jaming code, open front cover of the copier and then close it. if still the problem persist then "two part" the machine,open front cover, and press the green lever downside and the release it, now remove the paper from the machine where it is stuck and then close the machine and turn it on. code will be removed..........
Jun 17, 2010 | Konica Minolta Office Equipment & Supplies
I have a konica 3331 copier which is indicating an error message 36-01, i have don ea general servicing but the problem is still persisting.Please can you help me.
F36-01Low fuser temperature. It's can be some of the reasons. The Fault can consist in breach contact of fuse, faults of the lamp of the heating, thermo fuse and thermistor, if when okay - cose on the controller of the direct current. You recommend to apply to service - complex repair , requires the special knowledges and adjustments. Good luck
Oct 06, 2009 | Office Equipment & Supplies
I have a Konica 7020 copier reading an error code F-36-2 how do i fix it
Fuser error. Needs to be reset by a technician in service mode after the fault is fixed
Jul 22, 2009 | Konica Minolta Office Equipment & Supplies
Konica copier error code 36
fuser error, even though you didn't give any indication what model. Can only be reset in a service mode after fuser is repaired (fuse, Lamp, Thermistor problem)
Mar 05, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3331 copy machine ( osama tech )
JUST CHECK THIRMISTOR .IT IS DIRTY HAVING TONER ON IT JUST CLEAN IT .IT WILL BI OK
BY MIAN AKHLAQ
Oct 14, 2008 | Office Equipment & Supplies
Code 35-02 ( konica 3331 )
problem with fuser, check thermistor, thermofuse or lamp
Oct 06, 2008 | Konica Minolta DiALTA CF910 Copier
Konica 3331
make sure toner is full and corona wire leads havent come lose or broken.
How was the copy quality before the printer was moved also make sure mahine is level
Jan 15, 2008 | Konica Minolta DiALTA CF910 Copier
76 people viewed this question
k24674
