Question about RCA Televison & Video
My model number is M5OWH72S i fixd the bulb in the tv and when i power it on the tv does power on but no screen show up and the green power button blinks at me what do i do
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
  • 8457 Answers
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 07, 2010
circuitcity
  • 137 Answers
SOURCE: power button
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Posted on Dec 07, 2007
SOURCE: tv does not power on
If it blinks 7 times, your power supply is shot
If it blinks 10 times, a video board went bad.
Posted on Jul 13, 2008
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
My Sharp Aquos Liquid Crystal model number LC-60LE600U will not power on. I attempted to reboot the system but it still will not power on. Can this TV be salvaged without a very costly repair?
I've had this problem on one of my sharp tv's.
Have someone help you as it's hard to reach around a large tv sometimes.
Unplug the tv. Hold down the volume down and Handel down button. Now, have the person plug in the power for you. Continue holding the buttons and you'll see the screen flash or turn on.
If that doesn't work, try holding just the power button and plugging it in. If that doesn't work, try all 3 buttons.
You'll see the red light flash green or stay green and turn on. You might hear the power supply click on or hear the buzz of the inverter.
If it doesn't work after a few tries, the backlight bulb might be bad. It's probably been on too many hours, and so, the backlight will burn out. It's not worth fixing (if you can find one) so just buy s new one. That, or the inverter is shot.
Newer LEDs do not have inverters so it'll never burn out totally. However, it is possible for a single bulb to burn out, in which you'll see a dark sport or shadow effect.
Feb 01, 2016 | Sharp Aquos Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Hey i have a panasonic Plasma tv (model: TH-42PW5 ). When i press the button to turn the tv on the green light comes on and stays lit, but there is no picture - the screen is dark. What could this be?
The problem is either from the lamp or ballast. Have you ever changed the lamp/bulb of your TV?
When the LED shows green, it means it is a lamp problem.
The ballast helps to ignite the lamp and make it function well. So you might have to replace the ballast also.
Good luck.
Mar 18, 2011 | Televison & Video
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Green screen
You didnt Post your model number but from what you have said problem is the Light Engine. Go to this website and type in your model number they might have Parts listed for this set.
Mar 23, 2010 | Televison & Video
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blank Screen - Panasonic PT-50LC13-K
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Mar 16, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
