Question about HP LaserJet 1320 Printer
Paper comes out wrinkled in upper left hand corner. Help?
    President:
  • 1,653 Answers
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Posted on Sep 30, 2009
    Problem Solver:
  • 12 Answers
Either something is in the paper path, or more commonly, the fuser probably needs to be replaced.
Why is my paper coming out wrinkle Dell B1160W
Could be a number of factors.. first humidity affects paper, if there is moisture in your paper...caused by air conditioners constantly running .
check the paper by placing the back of your hand to the paper that is in the paper tray and or the package for a very cool feeling, this will definitely cause the paper to wrinkle when coming out of the fuser unit.
Also it could be charging of the paper during the transfer stage..which can be checked by starting a copy and trying to catch it before the paper enters the fuser rollers ..too late if it comes into contact with the upper and lower pressure rollers of the fuser unit.
Also the fuser unit definitely needs to be checked as a major source of wrinkling of copies..sometime the fuser roller will start loosing some of it's coating which you can easily check by viewing the condition of the upper roller.
Anyway it's either moisture in the paper, charging of the paper, or the fuser unit is the probable suspect.. check them all.
Jul 09, 2014 | HP LaserJet 2840 Printer
The paper wrinkles up while going through
This is possibly down to the upper fuser roller wearing and catching the paper when it goes through the fuser. The upper roller surface breaks up and splits
Oct 04, 2009 | HP LaserJet 1300 Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
PRINTER CRUNCHES AND WRINKLES PAPER WHEN TRYING TO PRINT
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 16, 2009 | HP LaserJet 3030 All-In-One Printer
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
My paper keeps "kinking"
Check the fusing unit.Pressure roller,pressure roller bushings, thermistors for over heating,fuser roller. replace if defective.
Sep 21, 2007 | Toshiba 1370 Black and White Copier
HP LaserJet 1320 Printer Logo
293 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
