Question about Mintek DTV-320 32 in. LCD Television
My television will not turn on. Seems like it may
My television will not turn on. Seems like it may be just a power issue problem
    Problem Solver:
  • 12 Answers
If there is no power at all, You may have blown out the power supply board. There is an easy way to find out. With the TV unplugged, take the back off. If you see some blown capacitors you need a new board.
If there is power i.e. standby light comes on but wont turn all the way on, then it could be in a different board.
Posted on Sep 30, 2009
TURN ON PROBLEMS AND SOLUCIONS
If a buzz or such and it seems to come from the power board its a transformer or coil vibrating hard enough to make the sound--not a uncommon issue.
Dec 06, 2012 | Philips 42MF531D 42 in. LCD Television
TV will not turn on seems to not have power.
If the TV "seems to not have power" then I assume that no lights are on or blinking, and that no noise is made by the television at all. This is most likely a power supply issue or a power chip issue. If you know anyone who able to solder or has working knowledge of electronics boards this could be a relatively cheap fix ($30+ in parts). Otherwise, you may be paying hundreds from a TV repair shop.
Mar 03, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
Two light are blinkin' in from panel. and tv
This seems to be a common problem. I have the same issue. Repair man says its a power supply (he thinks). When the lights start blinking, press the power button on top of the tv (not the remote) and most of the time it will come on and work. I am going to try to replace my power supply and see if that fixes the issue. If so, I will update this post.
Aug 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Make loud buzzing noise when powers on
Actually that buzzing sound seems that it might be an issue with your ballats, it may start to go out sometime soon.
Jul 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
My 53WUX10BA Red Power light will not go out
will not power up it worked fine then last week it stoped turning on it just turns off as soon as i turn it on
Oct 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Mintek DTV-320 32 in. LCD Television Logo
60 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
