Question about Zebra Stripe S400 Label Printer
Hi my printer is a Zebra S400 and when I turn it on all the lights are stay on and the pause and the cancel button lights keep flashing they dont let me do anything
  • 35 Answers
I think you may have a deffective printer, to arrange a service call, contact www.lancerlabels.co.uk
Posted on Feb 16, 2010
Zebra S600 all light on and the pause and cancel flashing
lucie_dibble: Maybe this is a electronic mainboard problem, try a printer reset pressing and holding PAUSE and FEED buttons then turn on printer, release buttons until all leds turn off. If this not work then replace the mainboard.
Roberto Martinez
padrino99@prodigy.net.mx
May 03, 2011 | Zebra Stripe S400 Label Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
The printerhead on my zebra printer keeps flashing amber, please help
load the paper and the Ribbon CORRECLY, check if the ribbon is not on top of the label sensors and gap sensors.
run manual calibration, press the last button until flash 3 times (to save), turn printer off, and on again.
If presist, download the correct driver (www.seagullscientific.com) run Reset to Factory Defult) from this driver.
Jun 21, 2010 | Zebra Stripe S400 Label Printer
We have one zebra printer, Model 105-SL , its not
You can try to factory default by turning the printer off, hold down the pause and the feed buttons. While holding pause and feed down turn on the printer and count to 5 and then release the 2 buttons and the printer will return to factory setting. Typicaly when all the lights stay lit its do to the logic board being bad but sometimes you can get lucky with the default.
Jun 06, 2010 | Zebra Z4M Printer
Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
Feb 24, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
LIGHTS ON PRINTER LOCKED UP
Try a reset: press the PAUSE and FEED buttons and turn the printer, release the keys when label feed.
Jan 19, 2009 | Zebra Stripe S400 Label Printer
Zebra z4m printer is displaying the pause and error light with no display.
Turn on the printer and never turn off pause and error leds? and printer not response? Then the main logic board must be replaced.
Dec 03, 2008 | Zebra Z4M Printer
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S400 Label Printer Logo
136 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
