Question about Akai Mpc2500 Music Production Center
After supposedly saving the entire memory to the autoload folder, and turning back on again, some of the sounds are missing. am i saving something wrong or is there some other problem?
I was just looking for some free advise.....
Posted on Oct 01, 2009
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
I just received my RSQ-echo 2000 karaoke machine. When I plug a mic into the front 2 mic inputs, they both have echo, even tho I turned off the echo volume in the back. I assumed that by turning it all...
The control supposedly controls the mix of the echo... this is a reverb type sound. Please note that room acoustics AND if the mic's "hear" the speaker in this, it may create an echo that is NOT under control of the adjustment. Make sure the mic's cannot "hear" the speaker or a reflection off a wall.
Aug 17, 2011 | RSQ NK 2000U
Need to identify and find parts for the Pearl FZH725/C85 Drum Kit. It was delivered with missing parts. Specifically Floor tom, 14" tom and arms to hold it. Need some direction and guidance, thanks.
I am a drummer as well in a classic rock band. Most the time when I need a part for something for my drums. I will go to guitar center. But to save money eBay is your best bet. You go to guitar center to make sure you have the right part, but don't buy it there . Match it up and go to eBay, lot of drum companies use eBay to sell there stuff. Thanks mike
Jul 22, 2011 | Pearl Forum FZH725/C85 Drum Kit, Zenith...
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Aug 20, 2010 | Akai Mpc2500 Music Production Center
I cleared one folder called WAVE with my computer and now there´s a messege on screen "data damage". the folder contains the preseted sounds inside. i need help.
Here's a hunch:
When the RC-50 was hooked up, your computer had access to the internal memory. The WAVE directory is where the wave data is stored. The RC-50 must have noticed that the wave data for patches that were supposed to have data was in fact gone.
So, you can probably just do a factory reset:
With the power off, while holding both single/multi and loop-sync, power the RC-50 up until it greets you with SYSTEM/PATCH use the PARAMETER buttons to go back and forth. In your case, you can probably leave "SYSTEM" alone and just select PATCH. Once you've selected which section of the RC-50 you want to reset, hit the WRITE button.
Aug 13, 2010 | Boss Rc 50
I have a triton le 61 and iI cant get it to save any sequences. everytime i try to save one it says ''error in writing to media. what should i do
Sounds to me like something corrupted on the memory module. May want to try another compatible memory card.
Jun 21, 2009 | Music
USB not saving audio. It gives CPU out of memory error.
Don't have too many folders on a flashstick try keeping everything into four folders maximum and I think you'll find it works perfectly.
Good Luck
Dec 21, 2008 | Peavey 32fx USB 32 Channel Mixer
Akai Mpc2500 Music Production Center Logo
46 people viewed this question
Top Akai Music Experts
Michial Gueffroy
T-Comtech Repairs
T-Comtech Repairs
Are you an Akai Music Expert? Answer questions, earn points and help others
