Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Machine not doing anything when you start
Only works on Spin cycle and sometimes on rinse otherwise does not do anything, any idea?
  • kashman12 Dec 20, 2007
    Is there a process to change the timer
    Sergeant:
    Champion:
  • 262 Answers
Timer replace it has dead spots
Posted on Dec 20, 2007
  • Bill Dozier Dec 21, 2007
    well kinda you have to access the control panel there are two screws on each side on the rear of the control panel remove them and then pull panel forward a little bit and push/pull up and fold to the rear but fist look at timer knob and see how the knob comes off some come off with a slight tug and some screw off gotta look close.after you get header open look at the timer some have screws and some just have clips remove wires you cant mess them up they only go one way. then remove timer install new timer and start putting back together its easy you'll see just jump in head first good luck and have a Merry Christmas
Top-load Whirlpool washing machine gets stuck on "sensing" stage of wash cycles
Hi my name is Charlie Lapinski. I will help you with your problem
is it locking the door at all?
Mar 29, 2014 | Whirlpool Washing Machines
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Troubleshooting whirlpool clothes washer
When our was doing that, we found after the cycle stopped if you give the lid a little push down, it would start up again, the inside clip just wasn't connecting all the way :)
Jan 07, 2013 | Whirlpool Washing Machines
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
59 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
