Question about Emerson CR202EM9 TV
Cant change channels or input using front panel/no remote
I bought an out of box display tv from Walmart and cant change any of the channels or input using buttons on the front panel. Its an Emerson 20in tv model # CR202EM9.Walmart refuses to give me the code used to lock the front panels of their displays and even if they gave it to me, I can not figure out how to enter any numbers!
  • Emerson Master
  • 8,457 Answers
Buy a new remote,tries this website for an exact remote or very closse to the original.1-800-Factory Original.
Posted on Sep 30, 2009
Tv does not respond to any input only shows nosignal to any device
Did the TV's source get changed? If you use the Television remote and find the source or input button which switches between the video sources for your TV such as HDMI, A/V, Television Tuner,, VGA connector or Component video. If your using a cable box that remote only controls the cable box and possibly the TV power and volume but the cable box remote does not change the source input of the TV. Most Cable boxes rebroadcast their video on a specific TV channel and your TV must be set to that channel to receive the signal from the cable box. Let me know if this helps you out.
Aug 20, 2014 | Televison & Video
Cant program the ****** tv channels and i want to watch cable. NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! please help seriously.
Hello truebamagurl,
If you have a cable box and you are using your tv remote, then you cannot get the channels. If you do have a cable box, then you need to use your cable box remote. If you do not see anything on the tv still, use the tv remote and look for input or source on the remote. Select it and scroll down and select each input until you see cable tv. (Now when I mean cable box, it could also be satellite). I hope this helps, good luck.
- Joe
Aug 31, 2011 | RCA Televison & Video
How do you change the 480i to the 720p using the remote
That isn't how resolution works. The resolution is changed in the cable box or satellite tv receiver. The television automatically displays the resolution once it has been changed on the cable box or satellite tv receiver. If you are on input tv on the Sharp television then it will not display any other resolution besides 480i if you have a cable box or satellite tv receiver. If you are not connected to a cable box or satellite tv receiver and you are on input tv then the resolution will differ from channel to channel.
Feb 10, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
How do I hook up a Wii? How do I change from TV to input mode? I don't have the remote.
You may be able to channel down on the tv from channel 3 to get to inputs. If not and there is no input button on your tv you will have to get a modulator from walmart or order a new remote for the tv. Do not get a universal remote.
Feb 27, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Program RCA F20352SF television to DVD player
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Aug 11, 2009 | RCA F20352SF TV
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Emerson CR202EM9 TV Logo
560 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
