Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Started to retune our tv this afternoon and it gets stuck on channell 68 and won't switch off, except manually. What should I do?? The set top box is Netgem. Thanks
  • Anonymous Mar 16, 2014
    Need to retune channels tomorrow in Sydney. How do I do this with Model TEL 828N?
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Posted on Oct 03, 2009
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Matsui helpline
Just go to your TV settings and just do a full reinstall ,like the day you brought your TV ,below is from the web site your tv will work hope this will help.
The Freeview TV guide is being updated on Wednesday, 3 September 2014 to create extra capacity for new services. As a result, Children's and News channels will move to new channel numbers.
• The Children's genre will move from channel numbers in the 70s to start at 120
• The News genre will move from channel numbers in the 80s to start at 130
To update their guide viewers simply need to retune their Freeview TVs and digital recorders or boxes where equipment does not pick up the changes automatically. On-screen messages will prompt viewers to retune late afternoon 3 September 2014 onwards.
Viewers who don't retune will not lose channels - services will remain accessible at their old numbers. However, Digital UK and Freeview recommend viewers retune from time-to-time to ensure they have access to all available services in their area.
Aug 29, 2014 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I bought a FERGUSON F20320DTR Digital TV Recorder At first I really liked the product but when I changed my TV from a really old one to a new LG 37LD450 I started to lose channels. At first I was unable...
If you are in an area that is being switched over from analogue to digitial you might lose channels to do with that. Another reason could be the leads between the TV and Aerial connections. Make certain that they have good connections and use proper screened cables. Some people also have several transmitters around them, some of which have weaker signals than others. Some channels will therefore not appear. Check the box is tuning into the strongest signals.
If you manual retune then find out the frequencies of the strongest transmitter in your area first and set it on them.
Aug 23, 2011 | Televison & Video
I need to unlock my Platinum Telefunken set top box. My remote won't work at all and I put new batteries in and it's not that. The green light is on "Lock" on the actual set top box....
I have the same problem, but with no picture at all on my HD Channels. All I did was to retune my TVs analogue channels and bingo I got all my HD Channels back. My HD Set Top Box is still showing as locked.
Aug 08, 2011 | Televison & Video
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
I have set up the sky box to have the RF power on but i cannot tune in the channel i want to receive the sky on the second tv
When you are in the rf mode there will be a number ,normaly 68.You may have to change it to another number ie 32 and try retune
Oct 05, 2009 | Televison & Video
Up until today samsung freeview tv model LE26R74Bd working fine: this am, will not do anything except volume control, stuck on BBC2, have tried new batteries in remote, leaving off for an hour. Buttons on...
PRESS THE DTV / TV BUTTON TO GET TO THE MENU.
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Samsung LE26R72B 26 in. HD-Ready LCD...
HOw do I retune old TV set(not digital)with a digital set set top box for digital channels
connect the box to your tv then connect a digital tv antenna to the converter box, scan for channels and then your set.
Jul 13, 2009 | Ectaco EAL400T (English / Albanian)...
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
162 people viewed this question
Jerry Greenberg
Jerry Greenberg
