Question about Whirlpool Calypso GVW9959K Top Load Washer
Water is leaking from under the plastic strip on the front of my Calypso waster. It drips down the middle-front of my washer. Why do you think this is happening?
  • 101 Answers
Check all hose clamps and hoses and replace accordingly.
Posted on Oct 02, 2009
The washer is leaking out of the back of it. It is leaking from a black short rubber hose that has a clear plastic flat hose on it.
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso washer leaking
Sep 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a calypso by whirlpool, keep getting LD code, replaced pump with upgraded version last year. code started back again this week. removed hoses looking for obstructions, nothing, took out washer...
Did you check the impeller of the pump? These washers - Sears version included - seem notorious for eating clothes and sucking them into the pump's impeller, jamming it or clogging it. You have to stick your finger inside the plastic impeller pipes (in or out) and see if anything is wound around the blades. The upgraded pump is a single sealed unit that you cannot take apart or you'd probably void the warranty on the part. I find that articles of clothing tend to get pretty deeply embedded in the impeller and have to be carefully pulled out, and you can't see anything if you just remove hoses looking in them for obstructions. You can certainly remove the pump assembly and look down the pipes with a flashlight. When you removed the waster plate did you replace the gaskets/seals? If not, that can lead to problems with the integrity of the water tight seals that protect the U-Joint.
Jun 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Calypso washer leaking from overflow tube
Jan 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer leak
With the machine unplugged and EMPTY disconnect the water and waster water connection from the wall and tip it forward you should then be able to access the pump.  Check the hoses running to the pump. (usually white plastic with 2 large and 1 small hose running to it.. you can also just move it away from the wall with it completely connected and run it thru a cycle to see where it is leaking from.
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Topload washer dripping
of course its proably just a water valve leaking
Jan 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag SAV205DAWN, loud and leaking!!
the main seal is leaking and water has goy into the bearings,needs to be stripped and rebuilt
Nov 09, 2017 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
