Question about HP LaserJet M1522n MultiFunction Printer
During a fax, the paper jammed as it was feeding through.
  • 76 Answers
Pull it out firmly but try to not break the paper or you'll be there forever cleaning out the smaller bits.
Posted on Sep 30, 2009
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Paper jams when trying to send fax (original goes in short way then jams) unit has had little use it establishes connection and then stops and jams when commencing scan
look in paper path(scanner compartment were paper feeds) to ensure there is no pieces of small paper or foriegn items in this area preventing paper from going all the way through if this fails clean the feed roller in document scan area with a micrfiber cloth moistened with rubbing alcohol
Jan 13, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper jam
There is either a jam in there somewhere where you can't see it, or if it clears, the feed roller is not feeding the paper, in either case you probably need a tech.
Jan 07, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper feed jam
it will give you a break if the tires are not worn out. Look and feel if they are smooth, if they are smooth and shiny then replace otherwise clean with alcohol.
good luck
Dec 12, 2006 | HP 1010 Plain Paper Thermal Fax
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
HP LaserJet M1522n MultiFunction Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
