Question about Gaggia Titanium Espresso Machine
Keeps showing ventilate - Gaggia Titanium Espresso Machine
  • Gaggia Expert
  • 109 Answers
Remove the milk frother,press the hot water button,open the steam valve.
This should clear it.
Checked the frother for blockages.
Posted on Feb 24, 2010
I have a Gaggia Titanium, I did descaling, had difficulty during the process. It shows ventilate. I have tried priming, but it doesn't pump water through the nozzle
Hi.
Disconnect and re-apply power (unplug power cord). After that try doing rinse and descale procedure as from manual. You may need to keep adding water while performing the procedure.
See also: the ventilate error.
Regards.
Ginko
Apr 20, 2011 | Gaggia Titanium Espresso Machine
Hp2133 laptop heat fast why problem:
The laptop must be kept with a gap on any surface so that the ventilation fan works efficiently.
Now if the laptop heats you must remove the fan covers, the filters and clean them as the dirt accumulation would result in low heat dissipation.
Also do not keep the laptop on the bed as it will not ventilate but keep a flat board - or books- to keep it up.
Apr 09, 2011 | Computers & Internet
Shut down due to blocked ventilation
Don't block the ventilation, make sure to clean the filters, and keep it cool.
May 05, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Keeps showing ventilate. tried running the hot water. took removable machine parts out, cleaned, and put back. nothing works
Check the end of the steam wand, that could be blocked, if not then try this push in on the knob after you turn it open if that works, then replace the steam valve assembly.
Feb 25, 2010 | Gaggia Titanium Espresso Machine
Keeps stopping and display shows protect
I had a stero that would do this when it was too hot.See if when you cool it off it starts again . May need more ventilation.
Oct 10, 2009 | Sony Audio Players & Recorders
Ventilate shows.
try prime water on steam valve couple minuts if you have again message ventilate,that can be two reason,or your flow metar doesnt work or cpu board,but you try first prime water.
Aug 28, 2009 | Saeco Royal Professional Espresso Machine
Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Aug 06, 2008 | Audio Players & Recorders
Gem sound karaoke amplifier #exa1005
please confirm from your speakers cables in good condition and from your speakers.make maintenance to your amp by air blower-clean air filter-keep good ventilation around.after cleaning and good ventilation make test with any media while you are connecting one speaker only and then connect the other one.
Jul 06, 2008 | Gem Sound GemSound PA-585 2-Channel...
My x box is not loading any games and only showing the green x on screen and only showing 2 red lines on front panel
The two red lights means overheating. Either let your console cool down; or vacuum the vents on the back of the xbox to get the dust out. For further assistance, call 18004MYXBOX.
Tip: Keep you xbox on a cool ventilated area.
Apr 02, 2008 | Microsoft Xbox 360 Console
Ventilate
bad chip get if repair my friend good luck.to verify keep it unplug for some days then replug back.but since the posing of this article,you can plug it now and lets see what happens.if it does what it do again call a tech.your machine has a bad chip if it is the embbeded chip buy a new machine.good luck my friend
Jun 15, 2007 | Gaggia Classic Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
462 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
