Question about Verizon Communications enV2 Cellular Phone
My Env2 Screen Inside And Out Is Blank.
The entire top half of my phone doesn't work (part with both screen and front buttons) i dont know what to do
I just got a used lg env2 and for sum reason i cant dial out it says press ok key to unlock but nothing happens when i press the ok button. it still shows lock symbol in red color on the left of the front...
Have you tried pressing "Okay" then "Clear"? I know there is two lock features on it, and one is a double button lock. If that doesn't work there could be something wrong with the front keypad. Flip the phone open and see if it lets you unlock it that way.
Nov 02, 2011 | Verizon Communications enV2 Cellular Phone
I have a 20F42OT - is there someway to change the screen so the entire picture shows? for example, if there are sports scores on the bottom of the screen, you can see only top half. Screen should be...
does the remote have a aspect button? or maybe it is in the menu? If not let me know and I'll look it up. I have worked on some of these but dont remember them being wide screen
May 03, 2011 | RCA 20F420T 20" TV
How do you erase text messages from the LG VX9100 ENV2 RED when the screen inside is broken?
To delete single messages on an ENV2 with broken inner screen:
1) Go to your message inbox on your external screen to find the message you want to erase, but don't open it.
2) Open your phone and hit OK (to open message)
3) Hit the top left silver button, then OK.
Wait a few seconds for it to delete. If you know you have multiple messages right in a row you can skip step 1 and the first part of 2 (open your phone).
Mar 22, 2011 | LG VX9100 Env2
Dropped, now inside of env2 is blank
You phone screen is cracked and you need to get it replaced...it wont be too expensive so relax
Jul 08, 2009 | Verizon Communications enV2 Cellular Phone
Front keys will not work on my lg env2
Mine does the samething. Call customer support and let them know your phone is not working and you need a replacement. Mine is getting replaced. Mine started as just the "ok" button now it's moved to the 4-5-6 row. very frustrating.
May 31, 2009 | LG enV VX9900 Cellular Phone
Software update on Env2
One of the biggest problems with this phone is the OK button not working, and the front keypad doing the same eventually. Everyone I know with this phone has the EXACT same problem.
Mar 13, 2009 | LG enV2 VX9100 Cell Phone Car Charger
Env2 got wet, front keypad having problmes, "o.k" button doesn't work can I remove front cover, how??
This just happened to me last night. I FIXED IT!
The bottom half was working, the top keyboard was not working. The only button on the top that worked was the power key. Today, I got a screwdriver and took the whole entire thing apart. Start by removing the battery, then take out the 6 back screws. Gently pull the back apart - this will be tough, do it evenly around all sides instead of getting just one side and yanking or you might break it. two of the screws on the top are accessible readily, but the two near the hinge are only accessible once the back is apart. Take the front apart with these 4 screws. dry it out with a q-tip. There should be four more screws inside - take those apart and dry clean. Pull the face off and dry the large white plate that receives all the button action. I put it all back together and my buttons worked again. I didn't even feel like I did anything to fix it because it wasn't really wet inside, i think there was just a micro-dot of moisture on that white plate. I hope it works for you. I was so excited about mine that I got on here to tell others. But hey - I also prayed about it and God cares even about the little things!!!!! Now - I've got the battery out and am leaving it out for a couple of days just to make sure that its totally drive because any water in there could still damage the phone if there is a power source. GOOD LUCK!
Mar 09, 2009 | Verizon Communications enV2 Cellular Phone
When i open up my lg verizon wireless env2 mobile phone the inside screen is blank and will not work, but the out side screen works.
you have to go into your display options it will list your main display and your front display. on your main displayis the inside one. your outside is considerted your clock display option press the select and edit this should give you the desired options you can choose for it. pick the one you want and then hit save. this should do the trick..........please rate this
Sep 21, 2008 | Cell Phones
Verizon Communications enV2 Cellular Phone Logo
188 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
