Question about IBM ThinkPad T20 2647 Notebook
Thinkpad T20 no boot
Hi, I have a thinkpad T20 that I am repairing. presently, it will not boot up. powers up ok.. has memory, hard drive and cpu.... but nothing happens beyond that... ie screen stays black. you can hear the fan running... I also replaced the cmos battery. that's about it. no beeps with all dimm slots filled. with dimm slots empty.. get 3 beeps twice then 1 short beep.
Thanks,
Mike Moss
  • 6 more comments
  • mrm777 Dec 20, 2007
    Thanks for trying... already tried that however... Mike
  • matwood Dec 23, 2007
    it powers up but won't boot the fan is on but no bepps
  • Anonymous Dec 28, 2007
    I have had the same problem. I think it has something to dow ith the squareX symbol next to the battery power button on the right side of the laptop but I'm not sure. Does anyeone know how to get it to work after this has happned?
  • Rogie Jan 04, 2008
    Hello! My friend's T20 doesn't power on. The battery indicator is green. The hard disk indicator lights but stops when you press the power.The other indicators do not light when they should be to indicate that the laptop is on. No LCD display. The laptop is not working...
  • Anonymous Jan 07, 2008
    I notice the square x light doen't light. When I get the laptop to turn on the sq x comes on. What is this and how do I get this fixed?
  • Anonymous Mar 17, 2014
    X200 thinkpad seems to run ok, but on completion of boot there are two short beeps and then it continues seemingly to run OK. Should I be worried?
    Laptop seems to run OK, however, toward the end of boot up there are two short beeps, and then it continues seemingly to run OK. Running idle at about 37 - 41 C, and working in the high 50's. Running WIN8 Pro.
  • Anonymous Mar 24, 2014
    no power no beeps the adaptor ok memory good condition and processor ok
The ThinkPad T20 overcharge the capacitors and this is why do not start even when the lights are on.
To fix the problem, disconnect the ac adapter and hold the on / off button for about 60 seconds. After that, reconnect5 the ac adapter and turn on the computer.
Posted on Jan 19, 2008
    Novelist:
  • 188 Answers
The laptop is not booting up at all it sounds like - I have seen a lot of t20 series laptops fail this way.
First try an external monitor to make sure it is not an LCD issue.
Then try a replacement CPU. If that doesnt do it the motherboard is probably bad. I have one here right now doing the same thing about 1/2 the time.
replacement mainboards seem to be cheap these days though - here is a bottom half of the machine for sale on ebay:
http://cgi.ebay.com/IBM-ThinkPad-T20-T21-Motherboard-P3-850MHz-CPU-R22_W0QQitemZ250204010810QQihZ015QQcategoryZ60268QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Jan 10, 2008
  • 23 Answers
Try plugging it into an external monitor and see if it shows up,or without monitor,hold in the fn key and press the F key that had a picture of a monitor on it.
Posted on Dec 23, 2007
  • 80 Answers
TRY TO GO OLD SCHOOL AND USE A WIN 98 SART DISK OR TRY TAPPING F8 ALOT DURING START UP AND SELECT STEP BY STEP START
Posted on Dec 19, 2007
IBM Thinkpad 2647 will not power on , i plug it in to charge and orange light flashes 5 times then stays solid orange . I can leave it plugged in for days and will not change , it will also not turn on...
This is a tricky problem, you need to troubleshoot this bit by bit - first take the memory out one stick at a time and try to turn it on each time, then try the hard drive. If it boots further with one of these things out then you know thats the problem. If it still doesnt boot after trying these components then you need a repair as it will be an onboard component.
My immediate guess would be the onboard power supply unit, unless your charger is broken and you can test with another charger to rule that out too.
Feb 26, 2011 | IBM ThinkPad T20 2647 Notebook
I want to boot my laptop from a external hard drive. It is an older PC, a IBM Thinkpad T20. How can I boot from an external hard drive? Can anyone help me?
during start up press f12 key then when boot order opens select where you want to boot from . save then exit in to start up . that should do it . :)
Jul 10, 2010 | IBM ThinkPad T20 Notebook
ThinkPad T20 2647 PC Notebook: The lap top will not boot. It's a thinkpad T20...
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
May 17, 2010 | IBM ThinkPad T20 2647 Notebook
Shutdown the laptop icant boot thinkpad t20 again
is there an indicator lights that acknowledging there is power or none?
Apr 12, 2010 | IBM ThinkPad T20 2647 Notebook
Laptop Not booting - No Screen
Clean your memory card, or reseat it. Clean the edge connector with soft eraser if reseating doesn't solve it. Do this when battery is disconnected, completely turn off and no other power supply is connected to it. If not maybe ram failed already. This is the first step before going to anything. For additional instructions try to find it in youtube. Post us some update.tnx
Jun 06, 2009 | IBM ThinkPad T20 2647 Notebook
I have a ibm thinkpad t20 and when the internal battery died the computer started asking for a password when booting up. I know how to reset the password on a desktop but this thinkpad has me stumped. Can...
the default BIOS password for this model is merlin but if that doesn't work you have a hard drive password set and may for lack of a better term be screwed. You can try zero wiping the harddrive from another system assuming you have the right cabling/adapters.
If the Hardrive is locked but the BIOS password works you can also acquire a new hard drive cheaper than a password cracker in most cases.
Hope this helps FixYa,
Chris
May 15, 2009 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Stuck at IBM Thinkpad Splash Screen
Sound like a memory chip has failed. Try removing the memory, I believe these have on board, but not sure. If it doesn't have on board, you will need at least one chip in. If the problem is still there, try removing the CD drive, occasionally they can cause a no start. If it's not the memory or the CD drive, then try a bios flash. You will need to create a bootable disc from IBM's support site using a different machine (obviously).
If the bios flash doesn't fix it, them the problem will lie with the motherboard.
Jun 27, 2008 | IBM ThinkPad T20 2647 Notebook
Ibm thinkpad t20 notebook
Could be a problem with the MBR or Master Boot Record.
It could be damaged. It's only a file system type problem not a hardware fault.
Have a look here.
http://www.ambience.sk/fdisk-master-boot-record-windows-linux-lilo-fixmbr.php
Mar 09, 2008 | IBM ThinkPad T20 Notebook
IBM Thinkpad T20 - Model Type 264784U
I would say the hard drive is failing. But need to run a diagnostic on it to be sure.
If you would like to know where to get the ibm / hitachi hard drive diagostic let me know. It's free for download and you can get a bootable ISO image to burn onto cd. Allowing you to boot from cd in order to test the drive.
As far as replacing, you should be good with a 60gb or 80gb. Did it orginally have a 20gb in it? I would say for most people, 60-80 is way more than enough. Unless you have a ton of music or pictures.
Oct 22, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
369 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
