Question about Kenmore Washing Machines
Our washer overflowed last night. no warranty on
Our washer overflowed last night. no warranty on it, we believe it to be the censor that controls the water levels. Are we on the right track??
  • 1,031 Answers
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit. This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port.First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.i f however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, Plug the washer back in (being aware that components in the console are now ‘hot’ and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged..
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. while it is the least common cause of overflow, it does happen and is easily overlooked. sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
Posted on Sep 30, 2009
I have a GE washing machine that the water does not turn off once it reaches the appropriate level. Last night it overflowed and flooded 3 rooms.
You have a bad water level sensor.
Look inside washer and check if anything is holding a float sensor down. If not, the sensor is bad or its connection to the control board is loose or not connected.
Jul 04, 2016 | GE Washing Machines
Will not spin or drain tried unplug and lid switch is fine fill ok
Susan call your service repairman the warranty should cover the fix .
Dec 09, 2015 | Washing Machines
Washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Jun 17, 2009 | Washing Machines
Er IF code
IF is the Ice Fan failure code.  The fan that sends cold air to the ice maker is frozen.  Unplugging and defrosting does not solve the problem.  Mine was fixed as a warranty item when I complained to LG since I had a similar problem earlier with the refrigerator fan within the warranty period.  The fix consists of replacing the ice maker fan and housing (the new housing has a drain hole to prevent freeze-up), replacing the freezer duct housing (again with design improvements), and a new control board (presumably with new defrost programming).
Jun 05, 2009 | LG LRFC25750 Refrigerator French Door
Overflowing washer
your water pressure switch is malfunctioning or the tube that connects to the bottom of the tub and runs up to the pressure switch is clogged. You need to get into the control panel and see if you see a clear hose. Remove it from the switch and either blow or use a small blast of compressed air to clear the clog. then try another wash. By the way do you use powder detergent? If so do you put it in before the clothes or after the clothes are in.
Apr 13, 2009 | Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Water keeps running will not shut off causes and overflow
If it only overflows while the washer is running, check the pressure switch, or water level switch. The hose may have come loose, or could have a hole in it somewhere. Otherwise the switch may be stuck or may need to be replaced.
If it's overflowing when the washer is off (i.e. in the middle of the night when there is no laundry in it), then check the water valve.
Mar 26, 2008 | Hotpoint VBXR1090B Top Load Washer
Washing Machines Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
