Question about Gardner Bender GB Electrical GDT-190A 19-Range Digital Multitester
How to test 12 volt with this meter?gdt-190a - Gardner Bender GB Electrical GDT-190A 19-Range Digital Multitester
    President:
  • 2,220 Answers
Set the center pointer to "20" in the "DCV" segment. Connect the black lead to "Com" the red to "V ω mA" HTH
Lou
Posted on Sep 30, 2009
PENTASONIC GB-190HD Manual
I don't think you will find a manual for a Pentasonic. I was conned into one in Tenerife in March 2013 and there is no address of any sort on the packaging or instruction manual. I am sure that is against EU rules. They seem to be manufactured to mimic a Panasonic model. That's what I thought I had bought until I got it back to the hotel.
Feb 11, 2013 | Gardner Bender GB Electrical GDT-190A...
Tip
12 volt battery test
I have seen many times a 12 volt car battery pass the diagnostic test performed at a repair shop but still fail while being used in the car.
A simple test to do at home is the cranking amps test. Place your 12 volt meter on the battery and check for 12 volts. Then looking at the meter crank the car over. If the voltage drops to 10 volts with all accessories off then the batteries cranking storage amps is weak. A bad scenerio would be the battery drops to below 9 volts. Below 9.6 volts there is not enough electricty to provide good spark to fire the engine.
on Aug 14, 2010 | Chevrolet C1500 Cars & Trucks
Where do you set the meter to test 1.5 volt batteries?
GDT3190 has a 1.5 V battery test position and if it does not have one then use DC Volts (V with straight line above) in any position higher then 1.5 V (eg. 2V)
Jan 27, 2013 | Gardner Bender Gdt-3190/gdt-190a Digital...
My gardner bender gdt 311 is not reading DC
there must be internal short somewhere - open unit up and check
Sep 27, 2012 | Gardner Bender GB Electrical Manual...
DO I NEED TO TAKE OUT FUSES OUT OF PANEL OF CAR TO CHECK THEM IF THIER BAD OR NOT
Two ways to check. You can take them out and test them with the ohm meter . Or leave them in circuit and test 12V to ground on each side of fuse. Notice the two small metal tabs on each fuse. Touch your tester to these. You should get a reading on both sides. If only on one (incoming) and not the outgoing then fuse is blown. Note it will only work if the fuse is on (key on acc if it is a switched fuse)
Oct 04, 2010 | Gardner Bender GB Electrical GDT-190A...
I used incorrectly , i tried to measure ac and .
If you have another fuse try it anyways.Mine has extras does yours?What you did will definitely blow the fuse.Let me know.Good luck!
Dec 12, 2009 | Gardner Bender GB Electrical GDT-190A...
ALTANATER NOT CHARGING BATTERY
you will need to test this to be sure if its not charging then take it out and have it tested for free at autozone and get the replacement parts there also.
have the new one tested as well.
put a 12 volt test meter on the battery with the engine off.
take reading
then check reading with engine running .
take new reading.
if there the same the alt is bad.
volt should be be low 12 volts when off and should be above 12 volts when on.
keep me posted.
jm
Jul 29, 2009 | 1987 Acura Legend
Test charger ey 0110
TAKE TEST METER ON DC VOLTAGE AND PLACE ON THE TERMINAL IN CHARGER SHOULD READ 12 VOLTS ON 2 OF THE TERMINALS IF YOU DON'T HAVE A METER YOU CAN USE A TAIL LAMP SOCKET AND BULB OR ANY DC LAMP OF A 12 VOLT RATING
Nov 26, 2008 | Panasonic EY6409NQKW 12 - Volt Drill/...
Gardner Bender GB Electrical GDT-190A 19-Range Digital Multitester Logo
973 people viewed this question
Top Gardner Bender Measuring Tools & Sensors Experts
Steve
Vuk B
Brett Duxbury
Brett Duxbury
Are you a Gardner Bender Measuring Tool and Sensor Expert? Answer questions, earn points and help others
