Question about Boating
Plugs are getting too much oil when idling.
I bought a used boat that has set up for a little over 3 months. The boat idles rough and keeps fouling out plugs. Once I get over 1200RPMS it runs great. When looking at plugs after they foul, they are solid black. Seems like they are getting too much oil. The boat has an oil injection system. How should I go about diagnosing this problem? Any help is highly appreciated.
  • 86 Answers
I would clean the carbs. I would bet that they are fouling out because your idle jet is plugged and that is causing the illusion of too much oil. If you clean out the idle jets then you should be able to run fine. You can also run the RPM's up pretty high and choke the engine out. Hold the choke until the engine is about to die and then release the choke. That causes a vaccum in the carb and can possibly **** the stuff out of your idle jet.
Posted on Oct 16, 2009
Rough idle on 99 chevy metro 1.3l engine. changed plugs good pickup but intermittent misfires. even when idling. also leak in exhaust system.
First thing, fix leaking exhaust, this can cause erratic idling...second thing, remove and clean IAC valve and MAF sensor..dry and replace, also try putting some SeaFoam in the petrol, engine oil and air intake, let sit for 10 minutes then go for 10-15 min drive...suggest you change engine oil shortly after driving about 5000kms, if the oil is old..
Did you get any codes on the misfire? If you did not, test ignition coils, test vacuum, test fuel injectors, verify correct plugs..That's right, anything from a fouled spark-plugs to burned cylinder head valves can cause a misfire. Whatever the root cause of the misfire, the bottom line is that one or more cylinders are not contributing to total engine power output. This leads to power loss, rough idle, unstable RPM and bad gas mileage...cheers
Jan 31, 2018 | Cars & Trucks
Just changed the timing gears and chain,now the car idles rough and keeps fouling out one of the front spark plugs.
Year/make/,model???? Was the timing chain replaced to correct this problem or has this problem developed after chain replacement? Compression test performed? High mileage on engine?
Jan 13, 2016 | Cars & Trucks
Idles rough and smokes when first stated
Worn valve guides allow oil to drain into the cylinders, causes blue smoke, fouled plugs will idle rough.
Coolant in the cylinders from a blown head gasket will cause white smoke.
Mar 30, 2014 | Toyota Camry Cars & Trucks
Hi, my1997 dakota with a 3.9 engine has a rough idle, has plenty of power i replaced plugs, wires, cap,pcv, rotor and added fuel cleaner. its a little better but still has a rough idle
My uncle worked at a dodge dealership as a head mechanic for over 30 years and he also found all of the 3.9 liter engines to have the rough idle. The rough idle cannot be explained but it can be made worse by buildup on the engine. I have a 2001 Dakota sport with the 3.9 and mine does it too and one of the first times i drove it it stalled and its not a Manuel transmission. But onc I changed the oil and put Lucas oil additive as well as regular additives to my gas every month or so it has reduced greatly and not stalled since. Hopefully you find this helpful.
Feb 28, 2012 | 1997 Dodge Dakota
Greetings all. Bought an 1983 Yamaha XJ650 Maxim late last year and love it. It ran great last fall and took it on a 2500 km road trip this June and it ran great. Two days after I got back it started...
Have you changed the oil and cleaned the air filter, after the fuel tap problem.
fuel in the oil can cause this symptom. the fuel ends up in the sump when the taps fail as yours did
also check choke is not stuck open, and battery is in good condition
Aug 15, 2011 | 1983 Yamaha XJ 650
We keep fouling spark plugs. I think our dealer purposely set the bike up that way. Now my son is a little older and knows how to ride but we keep fouling plugs. Is there an easy way to fix this...
Several ways to try. Be sure the air filter is clean and without any tears or punctures, install an in-line fuel filter, gap the spark plug at .030, be sure the stock spark plug is used ( NGK CR7HSA ), be sure the muffler not plugged up at all, increase the idle speed, and change the gearbox oil every 2 or 3 months. The only other thing would be to de-carbon the piston and head but that requires the head to be removed. Taking the head off isn't hard but you must be sure to have the valve cam timed properly when reassembled. If not installed properly, you can bend a valve the first time you try to kickstart. Please rate my answer.
Jul 12, 2011 | 2007 Yamaha TTR 50 E
91 tercel deluxe 158k idles rough like a cylinder is not functioning, computer does not show a fault code, drives fine at high rpm, gets 30gpm still. Any theories? or should I just turn the idle up and...
Pull the plugs. Sounds like you have a bad plug or a bad plug wire. Even an engine that misses will run well at high speeds but if it's missing at idle you might have a little oil on one of the plugs. I had a 91 tercel, ran great but leaked a lot of oil which would in turn foul the spark plugs. I'm sure you either have a bad wire or plug. Wouldn't mess with the idle, not sure what state you're in but it could impact emissions testing. Best of luck m'friend!
Greg
Nov 06, 2009 | 1991 Toyota Tercel
2003 cartier 4.6L 120K miles. Rough idle, at idle only.
has anyone checked for a vacum leak? a vacum leak will cause rough idle at idle. check the lines from the pcv valve.
Mar 21, 2009 | 2003 Lincoln Town Car
Omc specs
You will need to repost this in the correct section, this one is for vacuum cleaner repairs.
Jul 13, 2008 | Vacuums
Boating Logo
142 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
