Question about Microsoft Windows Vista Home Premium Edition for PC
When vista starts up it says stllog.dll will not
When vista starts up it says stllog.dll will not start or can not be found
  • 61 Answers
File may be deleted.
go to start type this in run
%systemroot%\system32\dllcache
find the file you will get your dll file right click on file click copy then paste it windows and windows\system32
it is done
http://xpvistatricks.blogspot.com/
plz vote me
thanks in advance
Posted on Sep 30, 2009
I got problem on SoundMAX.dll error
The missing dll SoundMAX.dll is the dynamic link library module of Staccato Systems SynthCore 3 Library software program.
The dll file as well as the included Staccato Systems SynthCore 3 Library program is produced by Staccato Systems.
SoundMAX.dll is an important component for the program and in the case it is corrupt or not found you can get Windows problem warnings similar to; "SoundMAX.dll is deleted" or "Staccato Systems SynthCore 3 Library failed to start because SoundMAX.dll is not found".
To fix the error, you need to replace the corrupted or missing SoundMAX.dll file with a working one.
The current version of dll file available on our site is 3.0.0.0 with a size of 1008 kb.
You may download the file for legally licensed software only.
You can download SoundMAX.dll for free by clicking the link below.
After you download the file, unzip it to Windows system directory ("Windows/System32" for
Windows XP, Vista, Windows 7). You can use Winzip or Winrar to extract files.
Press "Start" and select "Run".
Type CMD and press Enter.
Type regsvr32 *dllfilename* and press enter again.
Download SoundMAX.dll v3.0.0.0
Please note : No guarantees or warranties are given or implied.
Please download and install the file at your own risk.
Always take a backup of the original file in case something goes wrong
hope this helps
Sep 15, 2012 | Computers & Internet
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Missing wlidcli.dll
Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
run reginout cleaner to easily fix it
Dec 03, 2010 | Microsoft Windows Live Messanger
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
May 12, 2010 | EA - Electronic Arts Command & Conquer 3:...
Acad 2004 failed to start because ac1st16.dll was not found.
Just visit this site...
http://www.fix-all-dll-errors.com/ac1st16.dll/
this will help in case of missing or downloading dll's .
helped in my problem. :)
Jun 11, 2009 | Autodesk AutoCAD 2004 for PC
Windows sidebar stopped working
Here is a solution I found when I was having problems and it worked like a gem..its a problem with two programs running a .dll file:
1. Open a command prompt by being Administrator (Right click on Command Prompt and click Run as Administrator)
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
Then start up the sidebar.
Good luck. If you have any questions let me know.
Apr 02, 2009 | Microsoft Windows Vista Ultimate Edition
Uxtheme.dll is missing
You can download missing DLL from here
if windows explorer dont start use task manager-> run to copy missing DLL
Dec 24, 2008 | Microsoft Windows Vista Ultimate Edition
Errormessage keeps coming up Application has failed to start because msjter35.dll was not found reinstalling the application may fix this problem
After you download "*.Dll"(file extension dll) on your machine, copy it to
windows/system32/
Go to "start" ==> "run" and type "regsvr32 *.dll" to register the file to the system. For windows 95/98/xp/2000/vista,and win vista,no dlls is corrup!
where should this file go?
Please copy it to windows/system32/
We offer Free System Scan for Dll errors, ocx errors,and thousands of other frustrating Windows errors.Speed up your computer.
http://www.dll-download-system.com/dlls-download-m-/msjter35.dll.html
you will find the link and you can download this file
Dec 02, 2008 | HP Computers & Internet
D3drm.dll
Dear just install latest directX.It will run normaly.
Oct 25, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Premium Edition for PC Logo
196 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
