Question about Chaintech 7VJL APOGEE (CT-7VJL) Motherboard
Blue Screen/Motherboard/RAM Problems CT-7VJL KT-333
Setup:
Motherboard - CT-7VJL KT-333
RAM - 3 x 1GB 2700 DDR333 2.5V
CPU - AMD Athlon XP 2200+ 1.79 GHz
GRAPHICS - ATi Club 3D Radeon 9250 128mb DVI/TV 9258ATVD (Running 2 monitors - 1 via VGA and 1 via VGA off the DVI socket with a dvi/vga convertor)
2 HDDs 80GB & 500 GB
OS: XP service Pack 2
Hi I am having problems with my PC intermittently becoming plagued by the dreaded blue screen. As far I as I am aware the 2 most common problems for this are either bad RAM, or a corrupt install of windows.
So firstly I decided to look into the RAM, and eventually I downloaded HCIDesigns' MemTest.
On the first run (with all 3 sticks of RAM installed) I received multiple errors. According to MemTest even one error indicates bad RAM.
So to isolate which stick is the faulty one I tried booting the PC with only one stick at a time in the same slot and all 3 tests came through clean. I then repeated all 3 sticks in at once, with one error showing. Then I tried stick 1 and 2 (in slots 1 and 2), then stick 1 and 3 (slots 1 and 3), and finally sticks 2 and 3 (slots 2 and 3) together at the same time, all without errors so far.
MemTest suggests this may be a problem with the motherboard or bios settings, but I am not sure as to how I check this, because the BIOS settings are set to default, and I have never played around with them.
The blue screen has not appeared at any point during these tests...but I have also closed down all unneccessary programs while testing....and it has been known to appear a dozen times in a day and then not re-appear for weeks.
I really want to avoid a full windows re-install at this point if possible.
Is there anyway to check the motherboard (and its settings) or to repair the windows install if necessary without wiping the hard drive?
Thank you in advance, and apologies for the essay like lenght of this description!
    Problem Solver:
  • 13 Answers
Are the memory sticks the same speed and voltage. I know I had the same problem. 2 sticks where 2.6v and the other was 2.5v. The PC would run great untill the 2.5v memory stick got hot, then turn off the pc, reboot and pc would not post.Try downloading CPU-Z, and see whats going on. Here's the link http://www.cpuid.com/softwares/cpu-z.html
Posted on Aug 12, 2012
    Champion:
  • 209 Answers
Perhaps the memory is loaded and that is the reason why it is getting blue. have you tried cleaning your hard disk? have you tried removing some of your registries? we have softwares in the market, a registry dleaner, to defrag automatically once you scheduled, to fix your pc and so on and this is what i am using you don't have to worry for errors this is SYSTEM MECHANIC 4 PRO
Posted on Dec 19, 2007
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Hyhcan i fit a bigger processor to the asus K8V-MX Motherboard and more ram
Your motherboard can take any AMD Athlon CPU (this does not include the newer multi core or Athlon 2 CPU's), as well as up to 2 gigabytes of DDR400/333/266, ECC, non-ECC, un-buffered memory. That memory has to be split between 2 dimms as the motherboard will not work with a single dimm of that size. Also, ensure that when you do put memory in that the 2 memory sticks are exactly the same.
Mar 17, 2011 | ASUS K8V-MX Motherboard
My Asus A7V8X-X AMD Athlon 2500 motherboard was custom built. There are three fans, front,CPU, rear. There are only two motherboard connections, 1 chassis, 1 CPU. rear is disconnected. How can I connect...
If your rear fan has a small 3 pin connector and there are no connections of that type on your motherboard, you will need an adapter to connect it to a four pin molex connector from your power supply. Something like this...
http://order.store.yahoo.net/cgi-bin/wg-order?yhst-39083765508394+4to3
Aug 05, 2010 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Cpu
If functioning correctly, your motherboard will support the following types and speeds of CPU's
  • Supported Processors:
  • AMD Athlon XP/Sempron/Duron
  • Socket A processors
  • 200/266/333 MHz FSB
So likely it tops out at Athlon XP3000+ /333MHz
or
Sempron 3000+ socketA/462.
May 31, 2009 | SIS741GX-MN Motherboard
Memory +cpu upgrade
No to the cpu you selected. Board would not support that cpu. The RAM you selected would probably work but for how long I couldn't say. With prices pretty low right now it would probably be better to purchase a new motherboard, cpu, & RAM. Hope this helps.
Jan 10, 2009 | MSI MS-6367 Athlon XP 266FSB MicroATX...
BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Dec 12, 2008 | Abit KV7-V Motherboard
I have AMD Athlon XP 2200+ m7vit bravo m-b
All current 333 MHz capable Socket A chipsets (VIA KT333, KT400, nVIDIA nForce2, SiS 746FX) should be compatible with Barton based processors although you may need to flash the BIOS for the processor to recognized properly
your board has a 333mhz front side bus so should be capable of running them
You must ensure that the cpu is for 333 mhz and not more and that it fits socket A which your board is
Please post rating thanks
Aug 01, 2008 | Biostar M7VIT Pro KT400 ATX Motherboard
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Computers & Internet Logo
330 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
