Question about HP OfficeJet J4580 All-In-One Laser Printer
How do I scan a document. I have vista software and cannot figure out how to scan. so thought I could do thru the printer
    President:
  • 415 Answers
Follow the link for the directions on scanning.
http://h10032.www1.hp.com/ctg/Manual/c01368573.pdf
Posted on Oct 05, 2009
How do i scan a document so that i can attach it or save it to a flash drive?
It will depend on if you have the full software installed and want to use that software or another program. Put the document face down on the glass or face up in an Auto-document Feeder.
Launch the HP Solution Center (Start > All Programs > HP > HP Solution Center). Click Scan Picture or Scan Document and adjust the settings if desired and click OK. Set the scan destination and file type. Then press Scan. If you want to use the buttons on the scanner to launch the scan software on the computer, you need to set up the scan to destinations and settings in the Solution Center first.
WinXP, Vista and Win7 can acquire scans with Paint (File > Import from Camera or Scanner), Vista (some versions) and Win7 have Windows Fax and Scan (New Scan) and Photo Gallery (download from Microsoft for Win7).
I hope this helps.
Jul 27, 2010 | HP DeskJet F380 All-In-One Printer
Scanning problem
You are using HP PSC 1610 and There is an easy option available for you to scan documents/pictures directly to Email since you are using Outlook.
for this, you will find need to check if HP Solution Center is installed in your pc ? if not, you need to install it to make things easier for you.
If you have not installed the complete software for your printer, you will not find HP Solution Center in your PC.
Download the Software from this link :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=390315#N845
There is also a printing patch available incase you have upgraded your PC from Vista to Win 7
After you have installed the S/w, check for HP Solution Center on the Desktop.
Click on Scan Document and Click on DOCUMENT to EMAIL option and click Scan, The Scanned document will automatically get scanned and Attached to Blank Email.
Jun 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have an hp psc 1210, I have managed to figure out how to print from my comp, but how do I scan things to my computer
Scanning depends on a few things (OS, drivers). Did you install the full-featured software or the generic driver from the OS? (See the HP support site: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=90764& for drivers/software.) If you have installed the generic driver and a full software package is available, uninstall the driver, unplug the all-in-one from the computer and install the full software. Then reconnect the data cable.
Place the document to be scanned face down on the glass. (Document feeders need the document face up with the top edge entering the feed first.)
Depending on the setup, you can launch the software from your computer. Double-click on the icon on the desktop or (in Windows) Start > All Programs > HP folder and then click on the HP Director. (Once this software is set up for the scan destinations, if the monitor program is running, you'll be able to press the scanner button on the all-in-one to launch the scan. This is under Settings) Once the program is running, click Scan Picture or Scan Document depending on the item to be scanned. Adjust resolution and other settings as needed - try the default first. Click Scan. If doing a preview scan then click Accept when satisfied with the settings.
If you do not have the full software available for your OS or simply do not want to use that software, you have some alternatives. Windows XP, Vista and 7 all can acquire scans in Paint. (Open the program, then File > From Scanner or Camera) Some versions of Vista and Win7 included Windows Fax and Scan which also acquires the scans (just click New scan). Vista has another program that can acquire scans (Photo Gallery IIRC). Macs may have similar software available. In both cases, third-party software is also available.
If your computer doesn't see the scanner, check the cables. Scanners require bi-directional communication with the computer so a cable that allows printing can be a problem with the scanner. Try a new cable or plugging in to a different port. If you have a USB hub or print server, try a direct connection.
I hope this helps.
May 31, 2010 | HP PSC 1210 All-In-One InkJet Printer
Not getting pc to scan
ok...window vista as long as i am remeber got window photo gallery inside....you can scan you document use this window photo gallery.....or other choice you can use software utilities from HP.(the software came together with printer) if still cannot...you can download latest HP F380 printer driver from hp website......
could be the software together with printer just only for win XP...
Sep 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
Help with scanning feature for HP2355v
Click here to download software and drivers for Vista basic (not 64).: Microsoft Windows Vista
Feb 01, 2009 | HP PSC 2355v All-In-One InkJet Printer
Hp psc 1350 all-in-one
Source: HP support
( Click link above to read complete article and instructions )
Introduction A full feature software and driver package for Windows Vista is not available for your product. However, the Windows Vista operating system installed on your computer contains a basic driver solution for your product. With the basic driver, the buttons on the product do not function and some of the advanced product features are not available. But you can still print, scan, and import and view images on a memory card, using the workaround procedures in this document. Use the following instructions to install the basic driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the printer driver When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. Printing Use these steps to print from a software program.
  1. Open the document to be printed in the software application in which it was created.
  2. Click File , and then click Print .
Scanning Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367391.gif ) icon.
Oct 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP Photosmart C6280 Scanner
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart C6280
See page 80:
You will need the "All in One" software for your computer:
Software
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 23, 2008 | HP Photosmart C6280 Printer
Scanner
Please help me figure out why my Hp PCS 1410v won't scan
Jul 02, 2008 | HP PSC 1410v All-in-One Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
