Question about Patton PUH680-U Utility Heater
I have a titan heater model 368e 240volt thats needs a new fan motor where can i get one. tom
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: My motor on the Titan
WW Grainger
Posted on Nov 03, 2010
  • 674 Answers
SOURCE: Model # R110BT Serial @104068-02 This Heater,
Hi, first check for a capacitor on the motor. This is the sympton you will get if the capacitor is bad. You can test it with a multimeter.
Posted on Dec 08, 2010
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Is fan motor available?
Sure - but is the price of the replacement cost effective?
Dec 29, 2015 | Heating & Cooling
2011 Nissan Titan heater/ac fan blows on high we replaced the VBC it did not fix it, now what?
What is VBC? Ah, probably Variable Blower Control? my guess you got wires crossed, or a short around the control or even direct short to hot (12vdc) wire. Double check your work, wire connections. Instructions? with the new? double check.
Feb 27, 2015 | 2011 Nissan Titan Crew
If the little gray box has no trippers, the dial does not rotate,and the lever is on, is electricity being conducted to my water heater?
Maybe yes.
Open TP valve on water heater and see if heater has hot water.
If you want to test, then test across wires on terminals 2 and 4 for 240Volt. Test across terminals 1 and 3 for 240Volt.
To fix timer, buy new WG1573 240Volt clock motor.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 02, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
No hot water at all but power to all elements and to thermostats is there a dip tube in the rheem model 71-40D
Water heater can test for 120V power on elements and thermostats at all times.
That's because thermostats turn off one leg of 240Volt circuit, and not both legs.
You mentioned thermostats and elements, implying two elements and two thermostats, so your water heater is 240Volt.
240Volt breaker might be bad on one leg.
Open following links to troubleshoot
http://waterheatertimer.org/Test-electricity-to-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Yes the water heater has a dip tube.
http://waterheatertimer.org/How-it-works.html
Jul 10, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My WH40 makes a loud hum, but it works well. It is about 20 years old, and didn't make this noise until fairly recently. Could the motor be requiring replacing?
1) Yes, the noise is from clock motor turning the gears.
When timer is new, parts have a bit of white grease on them.
Turn off power and spray WD 40 or apply some white grease and see if that helps.
2) Yes
WG1573 240Volt clock motor is going bad.
Tip out mechanism using thumb spring located top inside box and check clock motor number.
Buy
WG1573 240Volt clock motor and extra trippers from Granger number 1PNK2
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
http://waterheatertimer.org/How-to-wire-WH40.html
Notice on image below, there is a bit of white grease on lever.
This photo is from new WH40.
Feb 22, 2011 | Intermatic WH40 - Water Heater Time Switch...
I need trippers for an older model Paragon water heater timer Model TC-2. Can you help?
I don't recognize Paragon TC-2.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic cross reference does not have that model number either.
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Paragon sent e-mail last month saying they were no longer making timers and parts, except for defrost timers. Your water heater timer is not defrost timer.
Here is a wide selection of water heater timers, electro-mechanical and digital:
http://waterheatertimer.org/Boxtype.html
Manuals and wiring diagrams are shown for most products on page.
I recommend simple 240Volt Intermatic WH-40 for price and reliability. Drawback is minimum 1 hour on-off.
Or Intermatic T-101 for 120Volt heater or T-104 for 240Volt heaters sold at Lowes.
Intermatic trippers and motors are available and interchangeable, and are made of steel.
Some new timers are made with plastic parts:
GE 15207 is universal 120V 240V and sold at Home Depot.
Tork has new universal electro-mechanical timer, TU-40 for 120 and 240 applications
I use GE 15070 in-wall timer from Home Depot for my water heater because I change times frequently and try to shave every dollar:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
Add a comment if you need more help.
You can also take advantage of fixya phone support.
Fixya expert will walk you through any problem for a price.
Dec 22, 2010 | Paragon Hardware & Accessories
I HAVE A EBAC HOMEDRY 880 dehumidifier LOOKING FOR A FAN MOTOR THE MOTOR AT PRESENT IS A MAGNETEK UNIVEARSAL ELECTRI LTD 220/240VOLT 50HZ 0.16A impedance protected
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Mar 20, 2010 | Ebac HD880 Dehumidifier
Blower motor on a/c furnace not coming on
could be a relay possible fan motor try put the fan to on on the thermostat if no fan one of the two relay or fan motor. you'll need a volt meter and know how to use it to solve problem It would be safer to call a contractor. Tom
Jun 18, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Fan Switch
it is the resistor pack that runs the blower motor it is shorted to the hi position
Jan 05, 2009 | 2006 Nissan Titan
Patton PUH680-U Utility Heater Logo
247 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
