Question about Datalogic Scanning DRAGON M131 WiFi SCANNER W/ DISPLAY Barcode Scanner
Battery has failed a s will not charge can it be replaced
    Sergeant:
  • 310 Answers
Here is a link to a store that sells the battery pack. I'm sure there are other online sources as well.
http://shop.barcoding.co.uk/product/id/18965/902201789
Posted on Sep 30, 2009
My lenovo tab is not working i were checked the charger also but the charger is ok
When a device like that fails completely, and the charger is charging there's only so many things that can go wrong.
  • The device has completely failed (worst case, but, not if nothing happened to it, no plugged in while lightning, no dropping, etc.)
  • The battery won't charge. If it's not easily replaced, see a battery store, they'll usually install one for the cost of the battery, if they can open it.
  • The regulator for charging the battery has failed. This means not only will it not charge the battery; but, it can't tell when the battery is charged, and it will kill the battery, this must be replaced by a repair shop, unless you know an electrician, and have the key to open the tablet.
Sep 02, 2015 | Lenovo IdeaPad Computers & Internet
Battery will not hold charge
This is an indication of memory in a battery or failing battery in the pack. Batteries should be run until they are flat then recharged and never recharged when they are part charged as they develop a memory of that charge point that the charger cannot overcome and will not charge past. If the battery in a pack has failed then there are battery re-acker shops that can replace batteries in a pack cheaper than a new battery unit and most probably with better batteries.
Jul 27, 2013 | kawasaki Drills
Inspiron mini fail to power on
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 21, 2013 | Dell Inspiron Mini 10 Notebook
Hi. I have new Samsung SGH-X495 and I have not used it for 3 years . I started to charge the battery for 7 hours but still charging. I just to find out either this is normal after 3 years charging or I...
Rechargeable batteries fail if stored for long periods in a flat state.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 28, 2013 | Cell Phones
Backup power ends quickly even with new battery
What is the load on the unit? How old is it?
The symptom can occur if the load is too large. It will also happen when the unit reaches a certain age.
I've found that the low-end consumer UPS's should be replaced when the battery fails. The charging circuitry usually fails to charge the battery even with a new battery soon after the replacement.
The way I check if the battery or the UPS charging system has failed is with a voltmeter to give the current voltage and a variable DC power supply (whatever is appropriate for the battery) to attempt to charge the battery. I can watch the battery discharge with an oscilliscope if I want a full trace of the unit.) Charge the battery fully then watch the unit over time. If the battery itself is bad, you won't get the full charge or it will discharge as soon as it is removed from the power supply.
I hope this helps.
(the server UPS's tend to be a better choice if you want to replace the battery and keep the UPS.)
Aug 21, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
Dell d510 battery not chargeing
Depending on how old the battery is, it may have lost its ability to charge / retain a charge.
Dec 30, 2010 | Dell Latitude D510 Notebook
I cant charge mine. it keeps making a beep
Two possibilities come to mind. 1) The battery has failed and can't be charged fully (usually one cell fails and it won't charge fully). I've diagnosed this by removing the battery and trying to charge it with a variable power supply. You can try replacing the battery.
2) The UPS itself is faulty and can't charge/maintain the battery. The entire unit should be replaced.
I recommend solution 2. I had the 725VA in this consumer UPS line and when I replaced the battery, the UPS could not keep the battery charged with any load on the unit.
Check your warranty, though. The APC warranty is for 2 years on this model.
I hope this helps.
Jun 02, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Starter battery will not charge
Hi
If the starter battery is not taking a charge, then it may have failed and require replacement. It is not uncommon for a battery that sits on standby for long periods of time to eventual fail. Best approach is to contact Kohler direct or one of their service agencies to get the correct replacement battery for the generator system.
You can contact them here
regards robotek
Apr 13, 2010 | Kohler 12 kW Emergency Power System -...
Battery Charging Failed on APC Matrix 5KVA
you will need to replace the unit. the charging circut has failed
Dec 27, 2009 | APC Matrix-UPS 5000 UPS System
Datalogic Scanning DRAGON M131 WiFi SCANNER W/ DISPLAY Barcode Scanner Logo
119 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
