Question about Powmax Computers & Internet
Hi!! Thank you for your time! We're doing our
Hi!! Thank you for your time! We're doing our annual UPS maintenance. I have (2) POWMAX UPS-500's that won't even power up. Does this mean I need to replace the unit completely?
  • 700 Answers
A few questions. Is it an stand alone one? seems to me a 500VA rated UPS, for light loads only.
Some stand alone common problem.
1. Battery for replacement
2. Fuse busted
3. Faulty relay
If repair and battery replacement outweighs the new one or got a small difference. Its better to have a new UPS unit.
Hope this helps
Posted on Sep 30, 2009
When i switch on my apc ups it started to make a noise and the light starts to flicker, how can i fix this? pls help me thank you.....
check battery voltage > 12.5 V if ok there is a fuse on the the internal board it might be defective, should be replaced
Aug 19, 2014 | APC BE500U Back-UPS ES 500 (BPAPWBE500U)...
APC UPS ES 500 series continuous beep sound and flashing green light
Hi Lasantha,
Check the battery in your UPS - it's most likely going bad and you will need to replace it.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 03, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
How much will a tuneup for a 2004 buick La Sabra
Generally speaking, modern cars do not require "tune-ups" like older cars. There are regular maintenance tasks and wearable components that need to be replaced, but the costs vary wildly depending on the shop and the brand of parts they use. Oil change, air and fuel filters, and, every 10k miles or so, spark plugs and wires are about all that needs done unless indicated. Also, coolant change, which I do annually on all cars I own.
Aug 18, 2012 | 2004 Buick LeSabre
I need to conect to my UPS via my computer . Not sure who to do this?
Is easy, here is how to do it:
  1. Plug your computer in your UPS
  2. Plug the UPS to an outlet/plug
  3. Start the UPS
  4. And done
If you want your monitor conected to the UPS make sure it has 2 spacest to plug them in or use an extension cord with 2 outlets or more.
Hope it was usefull
May 06, 2011 | MGE UPS Pulsar Ellipse Premium 500 UPS...
After i switch on the ups there are continuous beeps with red light instead of the normal green. if i continue to use the beeping stops after sometime but the red light persists. But then again the beeping...
ups with 300 watts can only back up 1 computer, though it can handle 2 computers but not too long. your ups battery life span are good only for 2 to 3 years. for battery replacement you can visit the nearest service center and ask for battery replacement. it will not cost you much.
Feb 10, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
On our 20kVa unit we got a 'battery must be checked" alarm. We replaced the battery but alarm still on unit. How can we get rid of this? We already did the normal reset but alarm still there. Thank...
The internal automatic battery test is picking up some differences between the actual value of the battery to the mathematical calculation used in the software. Normally if you do a battery impedance test you would find that the batteries would be consistent and therefore replacing the batteries may not be the solution. Once you transfer the UPS on BYPASS and then recycle the power you would clear the alarm. However on the next internal automatic battery you would be getting the same alarm again.
At times this may be a software issue or an SNMP problem. Normally to refresh the battery data for the UPS monitoring software we carry out a battery discharge test. Please consult with the supplier if an annually battery discharge test is mandatory for the battery monitoring circuit to work well. Please let me know of the outcome
Feb 04, 2011 | MGE UPS Galaxy 3000 UPS System
Needed pick ups
check out the forum on choppercharles.com - post in the buy/sell part - someone may have one
Jul 22, 2009 | 1982 Honda CX 500 B
APC UPS CS 500 (BK500EI)
If you can repair pcb then check overload protection section.There is some shortinng in components or ic could be demage.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | APC (BK500TW) UPS System
Computers & Internet Logo
54 people viewed this question
Top Powmax Computers & Internet Experts
David Payne
David Payne
Are you a Powmax Computer and Internet Expert? Answer questions, earn points and help others
