Question about Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp direction on how to change lamp on sony lcd tv. kdf-e60a20
  • 10,594 Answers
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Posted on Sep 30, 2009
4 Suggested Answers
asnowman
  • 788 Answers
SOURCE: TRYING TO CHANGE BULB
Here are the instructions and a link to your owners manual. Ref# page 76
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDFE60A20&LOC=3
On the back of the set, just below the screen, there will be two thumbscrews: one on the left, and one on the right. Loosen these.
Then pull the front panel below the screen off of the set. It may be stubborn, but if the thumb screws are loose, it will come off.
In the center, you will see a small metal bar with another thumbscrew. Loosen that, and swig the bar out of the way. That will allow you to remove the lamp compartment door.
Once you've done that, you'll see that the lamp cartridge is held in by an Allen head screw. An Allen wrench of the correct size is included with the new lamp. Loosen that screw, and you will then be able to pull out the lamp with the small handle on the cartridge.
Then just install the new cartridge, put all the screws back, make sure that tumbscrew on the metal bar is tight, or the set won't turn on at all, and you're done!
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to provide the best FixYa experience.
Posted on May 07, 2009
welcomejee
  • 10594 Answers
SOURCE: Where is the lamp on Sony LCD Model No. KDF-E60A20
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Posted on Oct 19, 2009
  • 17 Answers
SOURCE: where is the lamp for sony lcd projection tv model
its in the front actually. on either side of the tv right behind the side there are 2 screws you may be able to undo with your hand (if not a screwdriver or a dime will work), then front cover will pull off. you'll see it right in the middle. Another hand screw and a cover will expose the bulb housing. There is a allen screw on the left that needs to be loosened and then the whole assembly should just slide out.
Posted on Feb 01, 2010
I have a KDF-E60A20 that not only the pictures goes out every few minutes but the sound as well. Will changing the lamp solve both problems.
Yes, change lamp to solve both problems, if lamp has not been replaced in last 2-3 years then it is time.
Thanks.
Mar 21, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
My Sony KDF-E60A20 tv is not working this morning my lamp indicator was flashing is this a problem i can fix myself or is a service technician needed?
you can fix by replaced your tv lamp only.mostly lamp number menstion on top side. if not found then tell service center only model number of your tv and get your Lamp. Lamp replacement way menstion in Lamp user manual.
Oct 19, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
While watching the TV the screen goes blank. The LCD light is still good.
If lamp has not been replaced in last 2-3 years, get it replaced now because existing lamp is dying and causing problem.
Lamp replacement procedure is easy and written in user manual of your Sony KDF-E60A20 tv.
Thanks.
Aug 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the lamp for sony lcd projection tv model # kdf-e60a20 located in the back?
To replace the lamp go to link below then click on operating instructions. then go to page 76. It will tell you how to change lamp.
Dec 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
60 inch wide screen sony lcd
Symptom shows its Lamp Replacement time in KDF-E60A20 TV
If you have not replaced TV Lamp yet then change it.
Lamp is available in Part Store and lamp procedure is written in User Manual.
Mar 27, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf-e60a20 60inch
Yes, it's your thermal switch, had this problem and changed the bulb, no help. Got it checked by tv repair and they changed the switch.
Jan 08, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
376 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
