Question about Sony Ericsson K800i Cellular Phone
I get an update for my phone and wen i accept it says delete some profiles and try again. help
My phone got dead when i deleted profile from internet settings.
Deletion of profile from internet settings cannot result in becoming the phone dead. It is just coincidence. Update the phone by using the PC suite & an application to update the software from manufacturer's website as per instructions available in the application.
Jul 28, 2011 | Lands Phones
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Theres a update that dont want to download it keeps telling me to test xbox live? i tried to test it but right before it connects the update scream appears again.
Here's how I fixed mine. When I got the message stating that the download was unsuccessful I went into settings, then network, and I tested my network connection. During a network test it automatically logs your profile out, but when the test came back good, before it logged my profile back in, it asked me to update again. I hit "a" to accept the update and it worked this time. I think the key is that it has to attempt the update before logging your profile back in. I think the key is updating with the profile logged out, which under normal circumstances you can't do, only during a network test.
If that fix doesn't work you might try going into your network settings in the dashboard and lowering your firewall restrictions, then updating, then putting your firewall restrictions back to what they were.
Nov 01, 2010 | Microsoft Xbox 360 Console
I'm trying to download the new update and my game will not do it.I've already unplugged everything and replugged and still nothing.HELP!!!
Nov 01, 2010 | Video Game Consoles & Games
I have a product key fro windows home student 2007 what i got a while back wen i put it in it lets mje then wen i follow the instructions and phone it says something about piracy?? can you help please
Try this:
Go to Start-then-Computer - then double click on C Drive - then double click on Windows - then double click on system 32 -
then fin these files:
OGAAddin.dll
OGACheckControl.dll
OGAEXEC
once you locate these files first try renaming them. If that doesn't work try moving them (should work), if that doesn't work then delete them. Your copy of MSOffice should then be fine. Just do not accept any updates for MSOffice or any Genuine Advantage updates.
Hope it helps. If it does be sure and give me a good review.
Thanks
Oct 15, 2010 | Microsoft Office Home and Student 2007...
Wen ever i open music player and then play the song it show"not enough memory"......some body help me please
  1. I think your phone memory is full not the memory card
  2. delete or move the data from your phone memory and try again later
  3. if that is also not working there is an option called software updater which help you to  update you phone software
  4. else take the phone to near nokia service center they will update it for you
    Jun 18, 2010 | Nokia 5220 XpressMusic Cellular Phone
    Nokia 3110 blinks thrice and gets switch off again
    i sound like a software problem try updating it on the website with your data cable
    Jun 05, 2009 | Nokia 3110 Cellular Phone
    N79 freezes while accessing few application.
    That might any a problem with memory partition, try to remove external memory and formatted your memory with the handset..
    You can Reset your handset by dialling the no *#7870#.., please take the back up of your handset before doing that because it will delete all your data.. than try again. If it doesnot work than you have to get your handset flashed from your handset dealer. Nokia support number: 1-888-NOKIA-2U
    Nov 22, 2008 | Nokia N70 Cellular Phone
    Internet profile
    Ring Vodafone. They set all internet up from their end. All you will need to do is accept a text message from them. This then sets up your internet automatically.
    Nov 05, 2007 | Sony Ericsson K800i Cellular Phone
    Sony Ericsson K800i Cellular Phone Logo
    16 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
