Question about Panasonic DMR-E55 DVD Recorder
Problem to record
When I start the recorder, it only makes self check and nothing you can do. It doesn`t open, it doesn`t work. Can anyone help me?
  • 4,402 Answers
IC001 STRG6353 on power board may be faulty
Posted on Dec 19, 2007
DVD recorder dubbing/playing problems
your disc reader is dirty and needs cleaned..this can be done 2 ways.. one is to buy a can of electronic dusting spray, use the wand attatched to the nozzle .. stick the wand into the dvd slot and spray short bursts into the center area of the slot( dvds record and play from the center-out) the other is to find the screws that hold the cover on the unit(usually phillips head) and remove them..carefully remove the entire cover exposing the inner works of the recorder, again using the duter spray, clean the entire inside of the unit..paying close attention to the lens area of the reader..make sure not to blast it too hard and loosen the base..just enough to dust it off..then replace the cover and run the unit normally.. these units are quickly showing up at resale shops everywhere as folks are getting new digital recorders that record to a hard you may find a replacement there..I have several..
Jan 19, 2014 | Panasonic DMR-EH50 DVD Recorder
I can t record nothing my microphone doesn twork help plz,
I need to know if you're trying to record into a PC - if you are I need to know the IS - the recording program and the settings you have on the PC. What is the make and model of the PC if that is what you're attempting to record into.
If you're trying to record into a proper tape recorder or some type of other machine I will need to know the make and model of that machine.
Gary @ Fix YA
May 29, 2011 | LG Audio Players & Recorders
Microphone Help
Go to your sound properties and make sure it's not muted. Also, the recordind device should be the mic. Then open a recording application and give it a try.
Nov 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
Player shutdown and then go to self check
unit goes in to self checking over and over dvd can not be ejected and will not function at all?
Aug 05, 2009 | Panasonic DMR-E55 DVD Recorder
Built in USB mic not hearing me GDMALL 1370 on vista
Recheck default sound card settings in the Record setting. The device needs to show up. Make sure volume is up high enough.
Jul 09, 2009 | ASUS M2N-E SLi Motherboard
Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
