Question about Dell Inspiron 4100 Notebook
Lower 1/3 of screen is light blue band and can not see through it to access anything behind it
  • christine952 Sep 30, 2009
    First, thank you very much Spoem. The machine is not under warranty.As per your advice, I attached a monitor and it just seemed to not register my lap top, the little green light on the monitor would flash when I turned the monitor on, but then it would go to yellow and stay that way, and the screen just remained black.
    I also had no success with holding FN and power button on lap. The lap top turned off, but did not boot up again in Diganostic Mode.
    I would really appreciate additional assitance.
    Thank you, Christy
  • Barry Parks May 11, 2010
    First, is the laptop still under warranty? Second, do you have an external monitor that you can connect to the laptop to test the video output? If the screen on the monitor displays correctly, the display screen of the laptop is bad. You can also run a diagnostic check to test the system. To do that, turn the laptop off. In the lower left corner of the keyboard, you will see the 'Fn" key. Hold that down and press the power button, and then release both keys. The machine will start in Diagnostic Mode and will run a series of tests. One of the tests if of the video adapter. You should hear some musical notes, see color bars and need to press the 'Y' key to continue if you see the bars. If you do not see them, the video adapter is bad. That is part of the mother board in Dell laptops. Please let me know what you find and if there is any additional assistance I can offer. ~ Spoem
  • 3,940 Answers
You can try reseating the video cable under the keyboard. If that has no effect then you are looking at replacing the LCD assembly. Replacements are generally $150 or so on Ebay.
Posted on Sep 30, 2009
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
My sony 55" HDTV wega
Bad Light Engine,also called Optics unit Block- (Part Number A-1084-666-A)
Encompass Parts Distrbution 1-800-638-3328 $779.55 After Refund for exchange on old Part.
PTS 1-800-844-7871 This Company might have better Price for Light Engine-Rebuilt
Jun 17, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv screen on my sony wega shows blue in lower corner ... and growing. Anything I can do to correct this?
Replace your optical block/Light Engine, Sony is Famous for Bad Light Engines
Call UED 1-800-648-6657 or Encompass Parts Distribution 1-800-638-3328
May 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv 65rpwv600 just starts showing a blue colors on screen and after that it turns BLUE. i can't watch it but i can hesr it and also before this problems some very light lines (horizontals) were on the...
you either have a screen control drifting or a bad blue crt
you can access the screen controls behind the speaker grill and the black cover behind it the blue will be on one end or the other
there are 6 controls three are focus three are screen
turn the blue down slightly and see if it clears up before it shuts down the deflection if it continues to drift you might want to order a screen controls block and change it out
Oct 27, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Light bulb replacement
the light bulb is usually in cavity behind the control board.to access that first remove the outer cover of the unit by removing all screw at the back.after removing the cover u will have access to yhe cavity behind the cntrl board and the light bulb.....good luck.
Aug 19, 2009 | Emerson MW8168B Microwave Oven
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
Monitor is black and blue light flashing
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Mar 25, 2008 | Computers & Internet
Card Error
Camera says card error-blank blue screen behind it and it won't let me do anything.
Nov 16, 2007 | Fuji FinePix A340 Digital Camera
Pioneer SD-643HD5 64 in. Rear Projection
You need to replace convergence chips - they are behind the large black heatsink
May 22, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Dell Inspiron 4100 Notebook Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
