Today my daughter got ahold of my camera and now it reads on the screen focus error. and when i try to close it is makes a buzzing nose and the lense wont close up .
It's a message given when the internal lenses get jammed, possibly due to debris within the gears that move the focus. The "Focus Error" message can involve many FujiFilm models.
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
you can try 'knock' this to try free it but the motor that controls the focus is probably siezed.It's fairly common to get zoom/focus error with several types of compact camera, I think the cause is probably being switched on while in a case. I've dismantled one down to components to find it was the motor itself and been unable to do anything! If you want to sell it for parts, I'm after one - email me "[email protected]"
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
