Question about Bosch HBL 445 Stainless Steel Electric Single Oven
I need the cut out dimensions of the Bosch HBL 445 A UC oven. Does anyone have them?
Kimi
  • 277 Answers
SOURCE: HBL 445
Bosch main support number in US: 1-877-267-2499 Email support: Click here
Posted on Nov 27, 2005
  • 142 Answers
SOURCE: I have Bosch double oven HBL HBN and does not
sensors would not make it heat up any quicker element might be getting weak,but 10 mins to heat up is about normal.
Posted on Sep 28, 2009
  • 491 Answers
SOURCE: Hi experts. I have a Bosch Oven Model: HBL 745 A
FIRST CHECK FOR ANY BURNT WIRES THEN REPLACE THE HEATING COIL AND TERMOSTATS AND YOUR OVEN SHOULDWORK FINE, BUT MAKE SURE YOU CHECK ALL WIRING FIRST.
Posted on Nov 08, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
luke_bradfor
  • 662 Answers
SOURCE: Problem with the Bosch HBL
Do you have the complete E-Nr or Model Number available, and I will try to see if I have the pdf file for it
Posted on Aug 25, 2010
Oven heats slowy
Most often this would happen if one of the heating elements isn't working to pre-heat the oven.
Nov 07, 2013 | Bosch HBL 445 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 445 Stainless Steel single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 445 Stainless Steel Electric...
Oven fan not working
If you're referring to the fan in the rear for convection cooking (as opposed to the fan for cooling the electronics), it's replaceable by removing the oven rear panel (power off, of course). Bosch Part 490358
Jun 19, 2013 | Bosch HBL 445 Stainless Steel Electric...
My Bosch oven will not heat
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | Bosch HBL 445 Stainless Steel Electric...
Do you know if a 445 stainless out door grill will rust
The new 445 stainless has a higher percentage of chromium. It has a better resistance to rustingt that the standard 316 stainless, and is much easier to work with in the manufacturing.
So , short answer, It will last a very long time in the weather without rusting. ((never say never ??))
Please Vote !
Jun 05, 2010 | Bosch HBL 445 Stainless Steel Electric...
Oven takes twenty minutes to preheat to 375. Otherwise it works fine.
HI. In order to assist properly, i will need the entire model number. This will insure that any information given will be directed to the correct unit type.
Oct 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
HBL 445
Nov 25, 2005 | Bosch HBL 445 Stainless Steel Electric...
Bosch HBL 445 Stainless Steel Electric Single Oven Logo
171 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
