Question about Fuji FinePix A400 Digital Camera
I tred fliping the lock key up and down but it still wont work, i dont under stand how it would work one second , and then next next picture i try to take "card not initialized" pops up. if someone could please help me , i would greatly appriciate it.
    Brigadier General:
  • 11,967 Answers
Card not initialized means you need to format the card in the camera.
Posted on Sep 30, 2009
2 Suggested Answers
SOURCE: i have a fujifilm j150w and it keeps on sayin card not initialize
i dont think there is a solution to this problem. i have the same problem with fujifilm j150w and this stupid error usually happens when you are at the height of excitement in taking pictures. it is sooooo annoying.
a temporary solution to it though is just format the stupid memory card using the stupid digicam. you can still you it though. but you can't depend on the digicam for special occasions and important events. i really dont think its worth it
Posted on Oct 30, 2009
Keyless receiver
immobilizer control module under the dash.some vechicles if you replace key remote dealership has to reprogram remotes using diagnostic equipment.try this techinique to synchronize remote transmitter. stand within 5 feet from vechicle .press transmitter lock and unlock buttons simultaneously for 7 seconds . system will lock and unlock doors confirming synchronization. if this dont help dealership has to reprogram remotes.
Dec 13, 2013 | 1997 Chevrolet Blazer
Imobaliser failed and car not working
try this open driver side window lift bonnet lock all doors wait 3 min disconnect battery wait 15 seconds reconnect battery wait 10 seconds dont open doors switch on side lights through driver side window switch on ignition check system hold lock button on key down for 10 seconds remove key open and close doors check locking system now start the engine if no find the locking code for your car it should be with your car book its like credit card with some numbers on with those numbers you can unlock your imoballiser you have to turn the key to unlock so many times then towards locking side so many times and the numbers you have to find are with your car book if not you can get it on net it will cost you 10 to 15 pounds good luck
Dec 17, 2012 | 2005 Peugeot 405
Reboot system
Not sure how much you know but you seem clued up.Try switching off, turn on and press delete then scroll down and try to start up in safe mode. Have you had a power cut when trying to install up dates??? if this does not work try doing the same thing but pick restore to last known date. it took me a bit of time to work this out, use the cursers as your mouse wont work. would like a bit more info if these options dont work. Let me know please?
Jan 24, 2012 | Microsoft Computers & Internet
My cavalier Z24 1999 has a anti theft light on and is not firing up i even unhooked the coil and fliped it up side down and put a spark plug on the end of it and tryed cranking her no spark.. how can i rip...
need to find out why anti theft on --usually either worn key or worn ignition cylinder all the tricks in the world wont start vehicle thats why iits called anti theft
Jul 17, 2017 | 1999 Chevrolet Cavalier
How do you get a stearing colum unlock and the
hi if the problem is that the lock has locked and wont free when you try and turn the ignition on then what you should try is turning the steering wheel from left to right as hard as you can whilst you try turning the key, the problem is usually that the lock is under pressure from the tyres trying to turn the steering wheel so with this pressure on the lock the key just wont turn so you need to try and release this pressure so that the key will turn and unlock the lock.
so hold the steering wheel tight and turn it left using a bit of pressure whilst you keep trying to turn the key dont hold the key in the same possition as this wont free the lock keep turning the key on and off so that it resets and this should then allow the lock to free and you should be able to start your car, if turning the steering wheel left dont work then try right and repeat with the key on and off until the lock is off and the steering is free.
now it is going to be tight so you will need some force to turn the steering wheel as the force from the tyres will be quite alot so you will need to use force to work the steering wheel left and right whilst turning the key.
now if this still dont work then this will either mean you have a problem with the key or the actual ignition barrel has got a fault if this is the case then your going to need to get a new igniton barrel, the part the key goes into before the lock will free itself, all you need to do to remove the barrel is to remove the cover from the steering wheel surround and then you will see how the barrel comes out of its surround but dont do this until you have a new lock in case you forget how you got it apart.
the chances are the lock is just stuck and working the steering wheel left then right as far as you can will free it up if it dont then you can also try jacking the 2 front wheels off the floor like put the car on stands then try turning the steering left and right to unlock the ignition doing it this way releases the pressure from the tyres and should make it easier to unlock the steering.
let me know how you get on or if you need further assistance ok
May 23, 2010 | 1996 GMC Jimmy
My central locking on my 1997 vw golf just stopped working it sounded like it was trying to work but now does nothing. also the gas tank cover wont open as its stuck on lock...any advice on what i can try?
the gas flap is operated with the central locking,stand at rear of car with tailgate open,just inside to the right,under the floormat you will find the central locking pump.but first renew the batteries in the remotes then unlock the car with the key and hold the key over for 30 secs, the windows may go down,
then lock the car with the key and hold over for 30 secs,the windows may go up and the sunroof,if fitted will close,then unlock with remote button held down for 30 secs,this will reset alarm/central locking.
if you need to get to gas flap, pull carpet away in boot behind flap area and pull wire to unlock....
Mar 19, 2010 | 1997 Volkswagen Golf
How do you program a 2004 Malibu LT remote start key fob after changing the battery in it?
stand right next to the car and hold both the lock and unlock buttons down at the same time untill the locks cycle about 15 seconds
Dec 30, 2009 | 2004 Chevrolet Malibu
I have a fujifilm j150w and it keeps on sayin card not initialize
Jun 25, 2009 | Fuji FinePix A400 Digital Camera
Keyless remote does not work after replacing batteries
I had the same problem and located the addendum to the owners manual. It's kind of overcomplicated it seems. Here is what it says:
1) Confirm all doors are closed and the key is out of the ignition.
2) Open the driver's door and put the key in the ignition within 10 seconds.
3) Remove the key within 10 seconds.
4) Push and release the driver's door switch 3 times within 20 seconds.
5) Insert the ingition key within 10 seconds.
6) remove the ignition key within 10 seconds
7) press and hold both "lock" and "unlock" on the transmitter for more than 5 seconds within 20 seconds of removing the key All doors will lock/unlock to confirm the process has been properly done.
8) Press "lock" or "unlock" on the transmitter within 5 seconds of completing step 7. All the doors will lock/unlock to confirm that the process was properly done.
At this point the transmitter has been properly programmed.
Of course, this didn't help me. My transmitter still does not work. I did confirm the procedure with a known good transmitter, so it is valid. If the lock/unlock does not happen in step 7, you more than likely have a bad transmitter.
Oct 12, 2008 | 2003 Suzuki Aerio
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
Fuji FinePix A400 Digital Camera Logo
51 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
