Question about Toro Lawn Mower With Toro Power Tools
Need replacement engine or short block for Tecumseh LEV120-361541B
  • 437 Answers
Tecumseh has gone bankrupt so finding parts and engines has been difficult. i would see if i could find a B&S engine with the same bolt pattern to mount on the deck.
Posted on Sep 30, 2009
I have a 6hp Tecumseh engine that want take the gas when it runing!
possible part blocked main jet or low fuel supply from blocked filter in the tank
May 10, 2016 | Tecumseh Garden
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
My lawnmower, which is tecumseh enduro vt 20 hp, started smoking and made a loud pop. Now it won't even turn over. I've checked oil and power input. Where should I began? Does it have a starter?
yes it has a starter you should here the mower click when you try to start it but sounds like you blowed the engine up you have to short block it about 400 dollars.think before you do this is it worth it are there other problems with it how old is it if it is over 5 years old junk it buy a new one and dont ever by tecumseh engines my opion is that there junk easy to break buy brigges and stratton engine there the best not unless you want to buy japanese then honda lawn mowers are the best but i wood stick to brigges and stratton
Aug 07, 2014 | Garden
Tecumseh schematics
no bearing cast sleave in houseing if bearing is gone out will have to short block it
Jul 11, 2014 | Garden
Tecumseh small engine troubleshooting
Check point gap---gap to magneto/ fly wheel ---condenser--HT lead. switch wire is not shorted out.
Apr 22, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Using ariens snowblower today, model# 924026 and heard a ping and everything stopped. Tecumseh engine model3 H80 155006. Some white smoke came out and some oil leaked down side of metal part that oil is...
Check your compression tecumseh's are known for the exhaust valve seat poping out of the head. If you have compression check the governor shaft it should only turn about a 1/4 turn.
Dec 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Engine has seized up on snowblower. replace it?
either replace it or short block it, either way you will be re-newing the heart of your machine..... short blocks are typically less expensive
Nov 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a lawnmower with a tecumseh 173 cc engine that has experienced a sudden loss of power what could be causing this and how do i fix it
Ok, on the left side of the engine at the rear part of the block is a speed governor on Tecumseh vertical shaft engines. there is a spring that connects the governor to the throttle, if that spring is somehow broken or disconnected it can cause the problem you are experiencing. Check for that spring...if necessary, you can order a replacement through your user manual...cheers!
Sep 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have a yard machine snowblower that will not start
If the engine is infact seized, then it will have to be re-built or replaced. It was probably run with very low or no oil at all. You may be able to get a short block for your engine. All you would need to do is reuse your cylinder head, flywheel, carburetor, ignition modual, recoil houseing, fuel tank, governor linkages and controlls. The engine block and all internal parts would be replaced. It is far cheaper to just replace the engine rather than re-build it unless you are able to do it yourself and save the labour cost.
Dec 12, 2008 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Toro Lawn Mower With Toro Power Tools Logo
222 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
