Question about NorStar Meridian M7310 Phone
Line not in service
When I call an extension it says "not in service" and I get a really fast busy signal.
  • NorStar Master
  • 2,460 Answers
Is says that because it's not in service :-)
To check the extenson number of the phone you're calling, go to that phone and press FEATURE *0 and the intercom button. Read the display. It should show you the extension number of the phone.
If it has names only, you're probably going to have to start with 21 22 or 101 102 etc and see what rings.
Carl
Posted on Sep 30, 2009
WHY WHEN I TRY TO USE MY TELEPHONE I HEAR A BUSY SIGNAL
Are you on a party line? Is it a normal busy or a fast busy? Phone repairman can trouble shoot.
Sep 08, 2014 | Lands Phones
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
Is this service free? After a thunderstorm, our two Meredian 9516 phones will not work. The phone lights up and says extension in use but no dial tone, just a busy signal. Does the phone need to be...
Extension in use means there is not enough battery showing on the line. On our Nortel phone, unplugging the line cord gets the same result (actually check tel line because it's no voltage). Take a phone out to the demarc point outside and plug it into the jack there. If you don't have dial tone, report it to the telco. If you do, then you have an inside wiring problem.
Carl
Apr 04, 2011 | NorStar Meridian 9617 USB Telephone with...
Cant send or receive fax just get a fast busy signal when I try to send fax. please help
Normally a fast busy signal indicates a problem with the phone line. You need to call the phone company and have them do a "line check"
Sometimes they can fix this over the phone, sometimes a service call is required. No charge to you tho.
Mar 01, 2010 | Office Equipment & Supplies
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
Apr 10, 2009 | Panasonic KX-TA824PK Phone
Toll restriction override by account code.
It's not thatt simple. Look at 1.3.90 in the OM. You need to set a password and an extension COS on a secure set. For example, if you have a spare extension like 114, reclass it to COS 1, give it a password, then you can dial 7*xxxx114# press any line and dial the world.
The SMDR of the Walking COS user will show where it was made from. Needless to say, if the code is compromised, you have no security and no toll restriction, so be prepared to change the extension security code often.
The other variation is that you just change the class of service on those users authorized to make 00 calls so they can do it from their phone and let them use walking COS on a restricted phone.
Carl
Feb 16, 2009 | Panasonic KX-TA824PK Phone
Continuous Fast Busy Signal
Your modem/fax board is most likely bad. there is a relay on that board that has probably failed. It is stuck. I doubt it can be made to work. those are really small relays on those boards.
Jul 07, 2008 | Panasonic PANAFAX UF-6000 Fax
NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
Apr 18, 2008 | Lands Phones
NorStar Meridian M7310 Phone Logo
825 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
