Question about Maytag Dryers
I have a Maytag dryer model # PYE2300AYW. I went to start it up and I heard a straining noise from the motor, then the circuit breaker tripped. I took the front panel off and removed a large chunk of lint in front of the blower, then installed a new thermal limit kit. It still will not start. Any ideas?
    President:
  • 1,304 Answers
Sounds like one of two things
you still have something stuck in the sqirral cage
;;;;;the blower wheel;;;;;;
or the start winding on the motor is blown
i have new motors i can ship really cheap
Posted on Oct 03, 2009
What will cause my maytag dryer to throw the breaker when i try to start it
Not a dryer pro but if the dryer is on a circuit that's already loaded up, or is overloading your current one (amps wise) that could cause it, and especially if the breaker is weak. Could be shorted capacitor or drive motor, or heating coil short situation. (wire melts, ends up shorting against housing). If the breaker checks out, suspect the heater element next, motor last, I'd say. Good luck. Maytag Dryer Trips Breaker
Mar 15, 2015 | Maytag Dryers
Maytag Neptune Tripping circuit breaker midcycle
this looks like it may be your wash heater or your motor
if you take off your motor lead from motor if it still trips ???????? then look at the heater it wants to be replaced
Nov 22, 2013 | Maytag Neptune Washer Door Mah3000aww
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
Maytag dryer model PYE2300AYW dryer runs gets hot stops. when I try to turn it back on it makes a noise and won't start back up. What could be wrong?
It sounds like your motor is bad. you could take the dryer apart and clean off the lint on the motor and see if that helps but it sounds like i said the motor is faulty.
Mar 24, 2010 | Maytag PYE2300AY Electric Dryer
My dryer won't do anything. Maytag model PYE2300AYW REV 10, Serial 10604533ZU
First thing check the circuit breaker to see if it is tripped or if it is a fuse style if the fuse is blown. Next if that all checks out okay check the door switch and see tha the door switch is being made when the door is closed. The machine will not operate with the door open and if the switch is bad or stuck open then the machine will not work.
Jan 18, 2010 | Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AYW Dryer wont start or run. I replaced both thermal switches still nothing. What next?
Check the dryer breaker pair in the house electrical panel. Push off, then on. Try the dryer again. If works, ok. If not, recheck the breakers. If tripped again, the dryer has an internal short circuit--likely in the heating element(s). The drum must be removed to service the element(s).
Aug 28, 2009 | Dryers
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
158 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
