Dell Dimension 2400 PC Desktop
Problem for Dell Dimension 2400 PC Desktop
NIC error/keyboard fuse failed
By Marc Johnson on Dec 19, 2007
about a week ago my computer decided that it had had enough of life and when i boot it up it goes past the initial boot phase, where it gives you the option to go to boot menu or to system settings, and then 90% of the time it flashes up NIC error, then keyboard fuse failed and a variety of error messages with errors such as checkpoint math, PnP6, checkpoint poke,check point shut, and flashes the screen and bleeps with a messages saying to contact dell support, the machine is 3 years old so dell probably wont be interested in it and im running out of ideas, ive tried to wipe the hard drive and rebuild it but it still hasnt cleared it and the installation of windows xp crashed
So it seems like game over unless somebody can help me please!
Same Problem
Mar 29, 2009
-   each time i try to start up, i get an error message.
it tells me
failled at check point(poke)
and tells me to note down rhe checkpoint and contact dell techinical support.-   Guest
May 20, 2008
-   I have the same problem. I have a Dell Precision 470. One day it just die. Then i tried to switch it on, and the cpu fan started working heavily, like a vacuumcleaner!!. Then i opend it, and disconnected the harddisk, cd, dvd, ram memory, and the fan started working normally, but... i got all these messages, checkpoint poke, time...-   Guest
Apr 19, 2008
-   diskette drive 0 seek failure-   aqifpllaka
Apr 08, 2008
-   I Was Gavin A Dell Dimension 2400 That at Post It Would Show A Blue Screen, I Got It Past The Blue Screen To A Post Window.I figured Ok I'm All Right So Far.... Took Off The Side Cover To Discover About A Ton Of Dust, Lint, Dog Hair, You Name It Was There. I Cleaned It All Up Put The Side Cover Back On Booted It Up And Know I Get This Keyboard Error That I Cant Seem Too Get Past For Some Reason? It Boots to Every Bootable Disk I Have! I Changed The Key Board, I Changed The Battery, Cleared The C-mos, Changed The Hard Drive, A Clean Hard Drive With Nothing On It, With no Luck it Keeps Telling Me There Is A Keyboard Error And Too Run A Setup Program. With A Constent Beep. Can You Please Tell Me What I Can Try to Fix This Problem. Thank You Kieffer619.-   Guest
Best Solution
posted on Dec 19, 2007
Very Helpful)
gamebunny
Rank: Master
Rating: 86%, 40 votes
hear what u can do u can try resetting the bios or taking out the cmos battery for like 30 to 45 mins and the error u r getting will go away but if the NIC error keep accuring well there a problem with yr network card and for the hard drive when the pc is now booting up all dell normally comes with a testing device tool to get this testing device u can press F2 on when yr pc now going throught the post and just select hard drive testing...if it fines an error with the hard drive well u need to replace it....ok let me now if that work.
Was this helpful?
Yes
No
Solution #2
posted on Aug 12, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Yeah, I have the same exact problem, I keep getting the "Check Point [Poke]" Message. I am trying to get into the Bios settings but it is not allowing me to because by the time I get in there it crashes. Ughh... This is such a pain.
Solution #3
posted on Mar 12, 2009
Not Rated)
hi-walt
Rank: Apprentice
Rating: 0%, 0 votes
thank you very much,that fixed my problem
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 2400 PC Desktop
Questions and Unsolved Problems for Dell Dimension 2400 PC Desktop
Do you recommend Dell Dimension 2400 PC Desktop?
Answer
Answer
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2... (More)
Answer
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and... (More)
Answer
don,t write DWD-R+R-RW disk SH-S222A WinXP3, CD-R,RW ok ... (More)
Answer
I forgot to say in my last post that I do know about using Cntrl-+ or scroll to enlarge type size on... (More)
Answer
Hi there, Thanks for using fixya. What is the operating system running on PC? Since when you are... (More)
Describe your PC Desktops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in , MN
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
