Question about Fuji FinePix S2 Pro Digital Camera
Everything goes blank if the li batteries are loaded but works ok with AA batteries only.of course very slow
When charging what does blinking green light mean 18v
ITS LOADING if green light RAPID BLINKING SLOW BLINKING YOU HAVE LI-ION BATTERIES THE BEST IS TO HAVE THEM ALWAYS ON THE LOADER IF IN USE ; THERE IS NO MEMORY EFFECT OR TRAINING NECESSARY THAT WAS THE NICKEL CADMIUM PERIOD OF THE HEAVY BATTERIES , when a li-ion battery is too long without charging and using on time when the battery is below the dc level it should have it is possible that the loader will not accept the battery anymore, no problem take 2 short wires of a powercable and from a full loaded battery take the + connector and connect to the + with the problem battery and also the - to the - and wait for a moment 4 or 5 minutes that should be enough so the deep unload protection level is high enough loaded to accept the battery again on the loader MAKITA HITACHI MILWAUKEE DEWALT and much more brands its the most safe solution to get that dead battery working again. because not always is there a real problem but when too long inactivity 1 or 2 years on a li ion battery it is not dead or have only used one battery too long without changing it
Aug 23, 2017 | Drills
Is it ok if I replace regular AA battery with 1 Li ion battery for my shure pgx2 ?
not recommended for your camera . they have been known to explode if they get too hot .
Aug 14, 2015 | Cameras
Renault Megane 1.6 will not start
get the AA man (dolt ) back and have your friend watch what he does
not smart not to tell a customer what the fix is as it saves having to come back and do it again or show what has to be fixed to prevent a recurrence
probably just moved a loose battery terminal to make good contact again
May 30, 2017 | 2004 Renault Megane 1.6
Changed batteries in a coolpix l110 and cant get anything to work. No power and lens wont retract. tried everything in manual thus far with no results.
What type of battery did you use with your camera? Is the type your L110 support? Seems your camera use AA batteries, but not all of the AA battery which can put into your camera is OK. many cameras only support Li-ion battery or Alkaline batteries
Jun 30, 2011 | Nikon Coolpix L110 Digital Camera
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
M863 lens extends and then immediately retracts
Kodak Easyshare cameras use Li ion batteries, as recommended by the manufacturer, which have higher voltages but not necessarily higher amp hours per battery pack.
When I first bought my 14.1 megapixel camera from Kodak, I tried various batteries, including Alkaline, Ni MH, and they didn't work very long before needing replacement or recharging.
This is because the voltage isn't enough on other batteries.
I do not understand why they make it this way, because it fooled me a lot. I thought that since it had a AA format that it would be alright to use AA batteries of any type in the camera. But, this is not so, in my experience.
Good luck getting your camera to work with new Li Ion Batteries.
Note: if the Li Ion batteries do not work, then there is something wrong internally with your camera.
Contact kodak.com to see if it is economically repairable.
Thanks for asking a question on Fixya.com.
Jul 24, 2010 | Kodak EasyShare M863 Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
First, I am a 1st class amateur, so jargon is ?Greek? to me. However, I am studying the manual dilligently. My question concerns the batteries. I am using Panasonic Heavy Duty AA?s. I am always very...
It's essential that you state the exact make and model of your camera.
But in general many are incompatible with regular AA batteries (even heavy duty ones)and instead require that you use NiMh or even Li-ion rechargeablesinstead. The voltage, internal resistance and discharge characteristicsof these are significantly different to regular disposable AA batteriesand so the camera will report "battery empty" prematurely.
Check your manual again and if I've answered your query please return the favour by rating my answer. If not then please add a comment to my posting adding the required info for a definitive answer.
(Sorry for the repeat, FixYa ignored my instruction to post the above as an answer rather than a clarification request).
Jun 26, 2009 | Olympus Cameras
Using AA batteries in nec mobilepro 790
no absolutely not! i have not read that any were but if it was possible what you would have to do would be semi dangerous (for you and the device). if you want to take the chance then remove the battery (don't open the battery it self) then there should be some gold conecters that are on the battery and the nec there should be at least 2 conect the batterys to eachother and then to the conecters and hopefuly it will work (this is realy not that easy but you can try)
May 16, 2008 | NEC MobilePro 790 Pocket PC
Fuji FinePix S2 Pro Digital Camera Logo
29 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
