Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Stuck zoom too!
My Canon 17-85 IS also seems stuck at 17mm, though if I turn the lens upside down and am gentle, it will release. Not ideal tho'. Sounds like a loose element? I had not been 'rough' with the camera at all, so do not understand how this could have happened.
Any ideas? Solutions that don't involve hundreds of £'s at an Authorised Service Centre?
    Problem Solver:
  • 5 Answers
I had the same problem, but it was a case of getting a loose screw tightened up inside the lens.
I took it to an authorised dealer and it cost me the equivalent of about US$25 to get repaired, with the obvious advantage of not messing with the warrenty.
I also hadn't bumped my lens, and I only bought it in July, 2009.. so effectively, new. I did notice the zoom getting looser with time, and would fall out of the chosen zoom length when pointing down (and indeed, up).
Posted on Feb 16, 2010
How to repair or unstick Sigma K zoom 100-200mm macro - tele focus stuck at infinity
Remove the lens from the camera, set MF on the lens, try gently to free it by hand. If this works, clean the contacts on the lens and camera body - if not, it needs repair.
Jun 05, 2017 | Canon Cameras
Lens will not change aperture setting.. it's stuck on F4. Should be able to change to F2.8 Michael
You'll notice that the maximum aperture is specified as f/2.8-4.0. The lens has a maximum aperture of f/2.8 only at the 17mm focal length. At the 35mm focal length, the maximum aperture is f/4.
Does the lens open up to f/2.8 when you zoom out to 17mm?
Feb 17, 2011 | Sigma 17-35mm f/2.8-4.0 EX Aspherical HSM...
Turns on but turns right back off
It might be a lense problem. Dirt and things get stuck in the lense real easily. hold the lense while you tuen it on and when it turns off hold the lens out.. wiggle it gently while turning it upside down... tap it gently upside down.... or blow int he lens to try and get the dirt disloged.
Apr 13, 2010 | Kodak EASYSHARE M1063 Digital Camera
Zoon function stuck at 17mm
foreign /broken piece /screw etcmight have struk in the guide and between guide-pins.
Mar 07, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Cameras
Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Jul 05, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
17-85MM IS - mechanically stuck at 17mm - will not zoom -
Hi all,
I've had the same problem. So I decided to give it a try because I didn't find any solutions on the net. Unfortunately you have to pay pretty much for a Canon lens while the internal quality is pretty cheap, the whole mechanism is of plastic and this is also the problem. And after a while some screws will vibrate loose from the plastic components and canon could have done this better.
Probably within your lens is now one of the three zoom mechanism screws complete removed and you will notice that there is some abnormal movement in the zoom part. Unfortunately these screws are deeply mounted inside the lens and you need a lots of skill and patience to get it fixed.
First you need to completely disassemble the lens, and please make a picture of your lens after every step you make because I had to disassemble my lens 4 times! Because some of the elements was not right in place.
I will try to place a more complete description later today including some pictures.
Regards Gert
Aug 30, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
1,935 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
