Question about Panasonic RC-CD600 Clock Radio
Clock radio display shows incomplete numbers
Clock radio works well except for display showing incomplete numbers whether its on the clock setting or searching for a radio station
3 Suggested Answers
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
allinallelec
  • 407 Answers
SOURCE: clock wont set on Panasonic DMR-EZ48V
set time & date.try change memory ic or" repogram for reset the machine.
Posted on May 30, 2012
How do you set the time and alarm?
Do a Google search with the Panasonic model number and manual.
Jun 23, 2015 | Audio Players & Recorders
Why does my centro electric smoker digital display show incomplete numbers
I would say that just like any other digital display whether it be a clock, radio, thermostat, watch, or whatever, the display is failing. Sometimes it is the heat (too hot where the display is, like in the sun) and sometimes it is too cold (like cooking in the snow).
Jul 09, 2014 | Masterbuilt 20070106 Electric Smoker
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
Sony XDR-C705DAB wont set time
please press all buttons at a time it will reset
Nov 24, 2013 | Sony Dual-Alarm AM/FM Clock Radio with...
DURAGUARD CLOCK/RADIO MODEL CR777. CLOCK UMBERS ARE NOT LEGIBILE. NUMBERS APPEAR INCOMPLETE IN FORM.
This is caused by a bad driver ic chip that generates the numbers on the display chip. It is far cheaper to replace the radio than have it repaired.
Jul 05, 2011 | Audio Players & Recorders
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
Nov 11, 2009 | 2002 Honda Civic
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
Emerson Jumbo Display CKS2237 clock radio
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Oct 05, 2008 | Emerson Smartset Clock Radio
Panasonic RC-CD600 Clock Radio Logo
51 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
